I have just removed my after market steering wheel (wood would you believe!) and tried to replace with a tech 1 wheel. There seems to be an issue with the spacer thing that goes on before the wheel itself, if I put it on, the wheel doesn't seem to go on far enough leaving me with no horn, but if I leave it out the wheel has nothing to butt up against.
My question is, is there anybody out there that has a steering wheel currently removed and able to measure the thickness of said spacer. I think if I persist with it any more i'm going to cause damage!
Thanks guys.
A really big ask!
TouringTash
give me 5 mins
318i Touring
TouringTash
9mm fella
318i Touring
TouringTash
have you got a thing about Marge?
Any pics of the small of her back?
318i Touring
jacko
- Location: Too near Lakeside for comfort, even when in Spain
Thanks fella. Just measured mine and it seems to be 10mm. Do they come in different sizes or have I got problems I wonder?
And on the eighth day God created........The E30!
josh-hocking
- Teenager with Taste !
Touringtash's looks 10mm to me.
Sorry to ask, but have you turned the steering lock off?
jacko
Yeh lol i fell for that earlier on.josh-hocking wrote:Touringtash's looks 10mm to me.
I think i've sussed it now, the old wheel has worn the springy hexagonal rod that pushes onto the brass ring. I have just inserted the minutest of spacers under the plastic ring that screws to the boss and carries the brass ring. seems to be working now
