wiper motor problem
Jfogs
Fri Jul 23, 2010 10:52 pm
My windshield wipers will move all the way across my windshield when on intermittent but when they stop they come to rest in the middle of the windshield (right in my line of sight) any ideas on what could be causing this? the motor works fine and moves them with no problem it just seems to be maybe timed wrong or has possibly slipped?
Fri Jul 23, 2010 11:49 pm
or get a single wiper :D
silversideofthemoon
Sat Jul 24, 2010 1:15 pm
correct try the link that was sent just done mine earlier an worked tho i had no grease so used vaseline tho unsure how long it will last will repost if any issues but worked out very helpfull .....
h7fal
Sat Jul 24, 2010 2:29 pm
The link is excellent but you might find the metal disc inside the motor is beyond repair. Both my E30's needed replacement motors - easy to buy through the zone - due to excessive corrosion. I think it must get scored by the contacts.
1988 Tech1 325i Motorsport Convertible
2005 Porsche Cayman S
e301988325i
Sat Jul 24, 2010 5:04 pm
Jfogs wrote:My windshield wipers will move all the way across my windshield when on intermittent but when they stop they come to rest in the middle of the windshield (right in my line of sight) any ideas on what could be causing this? the motor works fine and moves them with no problem it just seems to be maybe timed wrong or has possibly slipped?
If they always stop in the middle of the windscreen, and exactly the same place on all modes then I'd suggest your linkage has slipped on the motor. If they stop in the normal position on continuous then I'd go for cleaning your contact disc.
I said:
e30topless said:
lock the wife in there
Jfogs
Wed Jul 28, 2010 6:38 pm
So what would be involved if the linkage has slipped? can it be readjusted or will parts need to be replaced?
silversideofthemoon
Wed Jul 28, 2010 8:25 pm
ye update on mine problem has occured again great, definatley use the proper grease but then av got new one on order anyway so hopefully will work for good this time hope ye sort it out matey
formally touringandy.............driving e30 320i touring and e39 535i
