Hi All, I have an e30 touring with the m30 3.5 engine it is being cooled by a air-cone fan set in front of the rad. The fan is hooked up to the speedo so that it comes on when you start the engine.
There is a fuse between it and the speedo which it keeps tripping.
I figure either the fan has had it or it is wired wrong.
At the min the brown is earth and blue wire live, is this right?
I have renewed the wires an rune one from the battery and the fan worked.
Any thoughts?
m30 3.5 e30 cooling issues
- E30 Zone Meets/Events Team
- Contact:
Why have you wired it up like that, most of us use a fuse and relay method, so the fan kicks in when needed.
The reason why the fuse keeps blowing could be down to 2 things, your fan is now fubared, or you're overheating the fuse by using the incorrect rating, which could also cause an underbonnet fire ir the wires overheat.
staley_turbo
a simple switch live from the ignition to a relay for the fan works the best. Id rewire it. Do a proper job.
