mine had the gaffa tape treatment, once i had fitted new ones, came to £30-£40 for all off them the car drove loads better at lower revs, and the idle was a little better too, was spot on to start with to be honest
Days work
Looks good, i hope your changing them taped up hoses with new ones
Banjo1981
Yeah, I also recognise the diction and generally poor english as armarnib's trademark.
As for the broken off pipe I think you may want to take it to a proper machineshop to sort out as I'm pretty sure nothing should corrode off a cylinder head.
Armanib thankyou.Banjo1981 wrote:Yeah, I also recognise the diction and generally poor english as armarnib's trademark.
Im guessing this is not a common problem so BMW wont have the part repair kit?
Ill be gone soon anyway banjo
- Kos
- Contact:
so this is the car who's number plate you're going to tattoo on your self ?
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
Jeez, they guy just wanted some help and people are straight in with the insults!
That's better things are getting back to normal around here!Daverave wrote:Oh why dont you just f*ck offross_jsy wrote:Lord it doesnt even have a real BMW engine.
Oh well, I am sure it will impress the crew at Maccy D's
- Kos
- Contact:
pop corns in the microwave
IG Pukar.Designs
IG Pukar.Designs
- E30 Zone Meets/Events Team
- Contact:
Cilit BANG!Daverave wrote:Whats the best way to get the limescale resembling stuff off the rocker cover and inlet
Its not limescale, its the alloy starting to corrode.
A wire brush and some WD40 will get it off.
HairyScreech
as bss325i said, its corroding alu, if your intending to paint it then use a good high temp paint ment for alu and it wont be back.
and for once he was only asking for some help and not being a twat, so i think some slack is due here.
as for the corroded bit on the head it could be due to a combination of factors, either poor coolant mix, or galvanic corrosion.
