eun wrote:um well ne1 know where i can get an
air chisle from?
is that like a mini pneumatic drill or summat?
or i will try the central locking module but not realy sure
how to do this process!
ne1 got any step by step advice?
cheers
to get the CL module
1.remove grille and speaker down by the pedals in the drivers footwell (1x Xhead screw for the cover and 3x Xhead screws for the speaker.
2. Locate the screws that retain the controller (Brass coloured XHead below hole for speaker)
3. Unscrew these and that should loosen off the holder (located INSIDE the hole for the speaker)
4. remove the holder and unscrew the unit (1x XHead screw)
5. gently remove the plug with the wires (push down GENTLY to release the clip)
6. clip new control module in and try!!
good luck
