Higher Octain higher Temp?
Felix79
All loved up !
Wed Feb 03, 2010 4:25 pm
Since October I have been running the car on RON99 Unleaded rather than 95. I know the car is not able to adjust it's timing but I thought I see what the car runs like with the stuff.
Because of the higher octain the fuel will burn at a higher temp would this also cause the engine temp to be slightly higher or would it not have any effect on it? Also because it's burning at a higher temp am I right in thinking it will be burning cleaner and would reduce carbon build up ect?
The reason why I am asking is that the car is running really really well and the only thing I have noticed is the engine temp is running higher. I've checked the usual bits to make sure it's not the head gasket and the pipes are all ok. Finally I know people have claimed that they find they get a better return on the tank but I am still getting 230 miles per tank regardless of my driving and would I be doing any harm to the car using the 99 petrol?
Felix79 aka Dan
E85 Z4M Roadster
Morat
Wed Feb 03, 2010 5:14 pm
Higher octane fuel will not burn at a higher temperature.
http://en.wikipedia.org/wiki/Octane_rating
HJG-E30
Wed Feb 03, 2010 6:18 pm
Typically the hotter an engine becomes the more efficient it becomes. However the components used within the engine cannot withstand in theory 'optimum' temperatures, and things begin to go wrong!
nomi
Wed Feb 03, 2010 6:46 pm
i used to run vpower in my 325i. its lasted 6 weeks then it blew a piston through the block.
i always push the car.
but it felt quicker with vpower
i don't use vpower any more
town325i
Wed Feb 03, 2010 6:54 pm
nomi wrote:i used to run vpower in my 325i. its lasted 6 weeks then it blew a piston through the block.
A piston threw the side of the block i would imagine that would be from something else and not running a higher octane fuel the only difference you will feel in a 325i e30 using this fuel is a lighter wallet
Wed Feb 03, 2010 8:01 pm
Running a higher octane fuel in an E30 than is required has NO effect at all on anything except your wallet.
If it does, then there is something seriously wrong with your car, as it must have been 'pinking' on the lower octane fuel.
It will be running 'better, at this time of year, as the inlet air is colder, and hence denser, than in summer, and as stated above, the hotter the engine the better, right up to the point it self destructs.
JWaller360
Fri Feb 05, 2010 2:26 am
Brianmoooore wrote: It will be running 'better, at this time of year, as the inlet air is colder, and hence denser, than in summer, and as stated above, the hotter the engine the better, right up to the point it self destructs.
Spot on, thats probably why it feels so much nippier than before :)
Felix79
All loved up !
Fri Feb 05, 2010 3:25 am
Back to RON 95 when I fill the car up this week end now. Thanks for the answers guys.
Felix79 aka Dan
E85 Z4M Roadster
town325i
Fri Feb 05, 2010 3:40 am
do the hot water delete off the throttle body that will make some difference
