rear axle removal
ezagood
Sun Nov 15, 2009 5:50 pm
im not having fun taking out the axle beam. everything is off but the beam bushes are rusted on. :( :(
dont want to use heat and damage the sealer/bodywork. hopefully it will fall off over night now ive soaked it in duck oil
braxtonator
Sun Nov 15, 2009 5:52 pm
tap em sideways abit and they get loosen
**BANNED**
Sun Nov 15, 2009 6:12 pm
You have belted the pins back up?
Put a bar in the holes where the pins go from the bottom and waggle,as the actress said to the bishop.
Then if you need to get really tough,a blowlamp to burn the rubber out helps!
Youth is wasted on the young.
Sun Nov 15, 2009 8:31 pm
Taking the trailing arms off first makes this job much easier
chiz70
Sun Nov 15, 2009 8:34 pm
I've just had the same delightful experience!
Had to be a bit rough with it but got it out in the end. The middle of the bush has siezed to the thread, THE JOYS!!
I've got the added joy that some cowboy in the past has welded the driveshaft nut to the hub!!!
Off to U-Pull-It to get a new rear axle tomorrow as original can't be saved.
ezagood
Sun Nov 15, 2009 9:00 pm
thanks for your advice guys. sorry to hear about your pobs chiz, ill let you know how i get on.
Nobody_You_Know
Sun Nov 15, 2009 10:41 pm
I had the same problem.
Set fire to the rubber and burn the fuckers out, then you can remove the axle and the extreme heat makes it easier to remove the aluminium center of the bush from the car.
Beemer 325i Track car currently in production.
Audi S4 currently transporting me around.
ezagood
Sun Nov 22, 2009 8:00 pm
got it off. as you can see i love working in a big pile of assorted items lol.
gona clean it all up propperly and paint it. ordered bushes and diff oil today. fitting an lsd too. going from 3.7 to 3.6. hopefully it wont make much difference.
ezagood
Sun Nov 22, 2009 8:05 pm
