where can i get bump stops from ?
kam-325i
- Contact:
Bump Stops.......As in the rubbers that fit top & bottom on the rear springs ?
got mine from gsf 18 pound somthing for the set.
kam-325i
- Contact:
The will be the Shock absorber Top Mount then......k13 wrote:its the rubber that fits between the top mount and the shock absorber on all 4 shocks.
GSF is you best bet....
not the top mount.
bump stop sits on the piston of the damper
these
these
They are internal on the billies aren't they?? So you don't need the one in the pics above.
TheMeathead
go to euro car parts they can get you some poly ones!
mine cost me 25 quid, i don't have billies though all i had to do was measure the size of the piston (width) and they looked to find the right ones
i do have a bit of an advantage as the guy who works there is into his bm's got a very nice
e36 328i
e36 328i
guys im struggling to find bumpstops for my bilstein B8s. eurocarparts dont sell them at all.
i know there is a place that do universal bumstops but they are asking for the the diameter of the piston rod and the length of it too....anyone know the diameter of the piston and what length the bump stop should be at for my bilstein B8 shocks ?????
thanks.
thanks.
that would make sense ! I have been looking too, don't they just have a protective Gaiter fitted to B8's ?k13 wrote:after carefull research people are saying that the front bilstein shocks have bump stops inside it ?????
B6 & B8's are the inverted style damper where the gas& oil cartridge is at the top of the strut in the shiny silver bit. That's why they are so fat, rather than just being like a thin rod. SO the thin rod part is facing down inside the yellow tube. They have the bump stop inside the yellow part of the shocker, so you do not need additional bump stops.
where did you get the Gaiter from lee ?E30BeemerLad wrote:
Morat
I'm sure beemerlad has got it right, but I've certainly managed to bottom out the back of mine on some bumps near work. A bit more cushioning wouldn't go amiss.
Came with the second hand B6's from Si13 matee30topless wrote: where did you get the Gaiter from lee ?
Put the dog on a diet MilesMorat wrote:I'm sure beemerlad has got it right, but I've certainly managed to bottom out the back of mine on some bumps near work. A bit more cushioning wouldn't go amiss.
You have to insert them into the strut which the spring sits on.k13 wrote:if thats the front shock how come my Bilstein B8 shocks dont have the spring support its just a long tube like as if there for the rears ???
the long tube fits into the strut housing (yellow side down) and the collar nut you can see in the pic covered in copper grease then holds that into the strut housing/ spring platform
I got these from the stealer's for my B8's ,
IMO they will just collect crap in the top
see if this link works .. only 2 left @ 94pence eachk13 wrote:ahh i see now man that got me worried.
e30topless: where did you get that bumpstop from ?
http://www.partsauction.co.uk/PartDetai ... 60F50D8BF9
it's not a bump stop it's made from plastic I think it's meant as some kind of protector ?
Ok guys...i fitted the b8 shocks and eiback springs and wow what a difference. very sturdy and rigid slightly harsh on the roads but that also could be due to my low profile tyres on my 17" rims. but going over bumps its perfect very controllable and keeps the car together.
thumbs up for bilsteins b8 and eibach pro springs. just need new rims now.
selling my 60mm springs if anyone wants it.
