Ive got a 325i manual e30, the only running problem im having is when you put your foot down, its very hesitant to rev up at any revs, after a few seconds it gets to the top of the revs but seems quite hesitant. Also, when cruising at a low speed at low revs in any gear the car seems to judder so you have to accelerate to stop the judder.
Ive replaced the plugs and leads recently and also checked all the rubber inlet pipes for cracks or split but they all seem fine, the tappets do need doing but has anybody got any ideas on what it could be?
E30 325i Running issues
Mucker_325i
blackcountrybimmerman
It could be any one of a number of things. As Morat suggests it could be an air leak from a hose, it could also be down to fuelling... perhaps blue temperature sensor, or even the throttle position sensor could be playing up a bit (they get gunked up with oil)
These are simple to check and remedy.
It doesn't look like it does in my sig pic anymore
Mucker_325i
Cheers mate, much appreciated. i will check tomorrow.Many thanks
bpowell555
What was the problem?
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby
Temp sensor and throttle pot how do you check theseblackcountrybimmerman wrote:It could be any one of a number of things. As Morat suggests it could be an air leak from a hose, it could also be down to fuelling... perhaps blue temperature sensor, or even the throttle position sensor could be playing up a bit (they get gunked up with oil)
Cheers,
Chas.
1988 325i auto Cabriolet
Chas.
bpowell555
You can check the TPS using the advice here:
http://www.pelicanparts.com/bmw/techart ... ooting.htm
1990 325i touring
