EXHUAST HELP !! before it gets dark
GT-UK
Wed Apr 22, 2009 8:53 pm
bit of an emergency
is a cabby (1991 but metal bumper) exhaust different from a saloon-touring-coupe ?
doing a bit of a swap over ..
long story..
but dont want to take exhaust from my touring if it wont fit on my cabby
help before it gets dark ????
changes on a weekley basis
Mayze
Wed Apr 22, 2009 8:59 pm
The main thing you would need to check it if the both have either a two piece or three piece exhaust. If youve got one of each you would need to change the whole shebang.
GT-UK
Wed Apr 22, 2009 9:04 pm
aside from that they will fit,
i started with a exhuast i had from a 86 325I coupe as a doner,
wouldnt fit,
this a 3 peice, you have manifold, centre pipe and box,
the rear section is in 2 parts,
the cabby exhuast had manifold, mid section and box, then rear section and silencer as a one piece ..
they looked the same in theory, but when i came to fit them, it wouldnt have it,
so if the touring has a 2 peice pipe,
im ok ?
Ant
Retired Team Member
Retired Team Member
Wed Apr 22, 2009 9:15 pm
pre sept 87 cars use a smaller downpipe flange and manifold, hence the non fitting for the 86 donor parts
the rest as per Mayze above, swop it all for a guaranteed one time fix.
GT-UK
Wed Apr 22, 2009 10:15 pm
cheers ant, ive PM'ed you ..
