bit of an emergency
is a cabby (1991 but metal bumper) exhaust different from a saloon-touring-coupe ?
doing a bit of a swap over ..
long story..
but dont want to take exhaust from my touring if it wont fit on my cabby
help before it gets dark ????
EXHUAST HELP !! before it gets dark
aside from that they will fit,
i started with a exhuast i had from a 86 325I coupe as a doner,
wouldnt fit,
this a 3 peice, you have manifold, centre pipe and box,
the rear section is in 2 parts,
the cabby exhuast had manifold, mid section and box, then rear section and silencer as a one piece ..
they looked the same in theory, but when i came to fit them, it wouldnt have it,
so if the touring has a 2 peice pipe,
im ok ?
wouldnt fit,
im ok ?
changes on a weekley basis
Ant
- Retired Team Member
- Contact:
pre sept 87 cars use a smaller downpipe flange and manifold, hence the non fitting for the 86 donor parts
the rest as per Mayze above, swop it all for a guaranteed one time fix.
Email FTW
