Safety Devices have definetly gone bump
austen_e30
Post Tue Jul 05, 2005 1:50 pm
Just phoned up a dealer enquiring about safety devices cages, and they confirmed they went bump 2 weeks ago :(
Looking for a multipoint bolt in cage, so who else can i try. I can't find any decent info (diagrams etc) on the OMP cages :(
Karan
Post Tue Jul 05, 2005 1:54 pm
ive heard OMP are good... try www.demon-tweeks.co.uk ...
Turbo-Brown
Boost Junkie
Post Tue Jul 05, 2005 2:02 pm
I've heard mixed things about OMP with regards to ease of fitting etc.
Shame about safety devices! I was gonna buy a cage for the GT6 from them :(
austen_e30
Post Tue Jul 05, 2005 2:04 pm
What about custom cages??? Just been looking on there site, they seem to be good prices. Anyone know what the difference is between plain end tubes and profiled end tubes??
Cotty
Hartge Crew
Post Tue Jul 05, 2005 2:10 pm
You could give these people a try http://www.rollcentre.co.uk/
Alternatively I think Sparco make a cage for the E30
Cotty
Hartge Crew
Post Tue Jul 05, 2005 2:11 pm
I saw a cage for sale in the parts section but I cant find it now anyone have a link to it
Cotty
Hartge Crew
Post Tue Jul 05, 2005 2:15 pm
Cotty180 wrote:I saw a cage for sale in the parts section but I cant find it now anyone have a link to it
Too late already sold, sorry
http://www.e30zone.co.uk/modules.php?na ... 57&start=0
austen_e30
Post Tue Jul 05, 2005 2:17 pm
bummer :(
M3Compact
Post Tue Jul 05, 2005 2:18 pm
I've got a Sparco cage in a Compact and it's 5hite, very poor fitting, we spent as much time modifying/improving it as it would have taken to make one, but we needed the certificate. :evil:
A friend has a Compact with an OMP weld-in cage which is excellent.
Customcages are also good, but more expensive.
Karan
Post Tue Jul 05, 2005 2:30 pm
Simon... get some pics up of ure compact...would be great to see it
M3Compact
Post Tue Jul 05, 2005 2:46 pm
Mine's just about finished now, oldish pic's...
This is the OMP caged car. (Lee Sawdon)
Not E30s, :oops: but they share the same rear end. 8)
Karan
Post Tue Jul 05, 2005 2:53 pm
wkd lovely prep there under the car
Cotty
Hartge Crew
Post Tue Jul 05, 2005 3:09 pm
austen_e30 wrote:bummer :(
Just clocked your name and thought it ringed a bell then I realised that I used to own an Austin A30
No im not that old before anyone asks if I got it new
Karan
Post Tue Jul 05, 2005 3:17 pm
me is liking the handbrake a lot :cool:
Andy325i
Post Tue Jul 05, 2005 3:27 pm
What an earth has happened to safety devices?!?!? I thouhght they were the number one cage makers :mad:
M3Compact
Post Tue Jul 05, 2005 4:04 pm
Brake Bias adjuster beside the parking brake too. 8)
I posted about this last week, I was really shocked, SD have been making cages since I was a young lad. (Long time. :oops: )
http://www.e30zone.co.uk/modules.php?na ... ic&t=11764
Karan
Post Tue Jul 05, 2005 4:10 pm
simon what handrake did u use... and where did u get the pipes and fittings from..im a complete novice with the pipin side of brakes etc...
i do know its fitted inline with the rear though
was there one line going back with ures? i think the e30 just has the one brake line going to the rears
M3Compact
Post Tue Jul 05, 2005 4:23 pm
Karan wrote:simon what handrake did u use... and where did u get the pipes and fittings from..im a complete novice with the pipin side of brakes etc...
Mine had one line originally.
They've all been replaced and re-routed inside with aeroquip and Goodrich fittings. (Demon Tweeks.)
Karan
Post Tue Jul 05, 2005 5:50 pm
is the handbrake assembly also from tweeks...... cos it looks like the one in the catalog
if so did u weld it to the side of the tunnel as usually these are placed where the stock handbrake is in a horizontal position :mad:
M3Compact
Post Tue Jul 05, 2005 6:13 pm
Karan wrote:is the handbrake assembly also from tweeks...... cos it looks like the one in the catalog
The hydraulic lever came from another car, but it's identical to the DT one. It's fastened to a bracket that's welded to the tunnel, I wanted to keep the standard parking brake and I find them better for leverage if my arm's extended forwards. (More Weetabix required.)
It's important to plumb the bias adjuster in front of the hydraulic lever, if you're using one, otherwise it restricts the lever output too.
Rally Design are cheaper than DT for this sort of stuff. Here.
Handbrake. Here.
Hose and fittings. Here.
Have you considered converting the standard lever to a hydraulic fly off? Cheap, and more convenient/civilised for a road use car.
Karan
Post Tue Jul 05, 2005 6:18 pm
yeh ure right i could convert it i guess by whackin a master cylinder in there somehow...
i do like the idea of an upright one though,...that was the whole reason really, as is the fact its right nr the wheel.... where u ahve placed it is where would be ideal for me.... :D when i have some time ill buy the tweeks one and make up a template and get my welder to weld up a bracket which i can bolt to the tunnel and bolt the assembly to
thing is with the e30... the tunnelm is wider i think and maybe it would get in the way of my leg.... but ill have to take a proper look to be sure
also when u do the pipe fittings.... dont u have to flare the ends... but the tool seems pretty pricey LOL any way round this ir would i have to take it somewhere to have done?
M3Compact
Post Tue Jul 05, 2005 6:33 pm
I've used them positioned behind the handbrake working via a bracket/clevis pin/rod from the top of the stock lever. You can simply take the clevis pin out for 'normal' road use.
Usually you can drill the lever and insert a removable pin for a 'fly off' arrangement.
This is an issue for me due to the 5hite Sparco cage, the main hoop is about 4" narrower than it could be which has forced my seat to be mounted further towards the tunnel than would be ideal. The hydraulic lever is a bit of a nuisance, but not as bad as the offset pedals. We can't even modify the clutch pedal because they're plastic in E36s.
You don't need a special tool for braided fittings. 8)
Karan
Post Tue Jul 05, 2005 7:10 pm
cheers for ure ever useful advice Simon!!
ian332isport
Post Tue Jul 05, 2005 7:30 pm
Karan,
I have a pipe flaring tool you can borrow if you need one.
Let me know in advance, and I can bring it to Brooklands. It's not something I use very often, so no rush to get it back to me (as long as I get it eventually :lol: )
Cheers,
Ian.
Karan
Post Tue Jul 05, 2005 8:26 pm
ian332isport wrote:Karan,
Cheers,
Ian.
cheers for the offer but i cant go brooklands unfortunately as i have an exam nxt week......
this isnt something ill be doing for a few weeks neway :D
cheers again
Karan
