So, i signed up to this forum in the hope of purchasing a new engine for my slightly rusted but not terribly dead BMW 316 E30, Planning to put a 325 Carbed engine in it. The problem is now, the headgasket has failed and the engine is full of water, Oil is brown and the car runs like a bad day at the pub, Lumpy and spewing up oil. I was just going to heave it right into the for sale section, wich is locked, But maybe someone could offer advice on Engien swaps, as after all, Replacing the engien would get rid of the need for head gasket work
Be good to hear from someone
E30, RIP
have a browse in engine swaps section,
depends how handy you are with the spaners,M50 is a popular choice!
Despite loving the original 2.5 unit a lot, I can't see why you would not go straight to an M50 (engine from an E36) in your situation. I would check out that rust on your shell before you go to the trouble, or it could end up only lasting a couple of years...
+1Morat wrote:I would check out that rust on your shell before you go to the trouble, or it could end up only lasting a couple of years...
good idea!
Theres a 4 inch hole by the differential mount mnothing i can't patch myself if i could get a jack under it. and one door is slighly caved and rusty, Again, easy swap. just don' knwo if its worth spending £1000's on a car thats been written off twice, i just really like the colourMorat wrote:Despite loving the original 2.5 unit a lot, I can't see why you would not go straight to an M50 (engine from an E36) in your situation. I would check out that rust on your shell before you go to the trouble, or it could end up only lasting a couple of years...
what colour is it?Akumu wrote:Theres a 4 inch hole by the differential mount mnothing i can't patch myself if i could get a jack under it. and one door is slighly caved and rusty, Again, easy swap. just don' knwo if its worth spending £1000's on a car thats been written off twice, i just really like the colourMorat wrote:Despite loving the original 2.5 unit a lot, I can't see why you would not go straight to an M50 (engine from an E36) in your situation. I would check out that rust on your shell before you go to the trouble, or it could end up only lasting a couple of years...
imo id start again it sounds as if you'd spend less buying a nice 325 as you would sorting out the problems with the one you have before you start changing engines..
if its a 4 door I've got a very good 4 door shell btw
They did a carb version of the 325?Akumu wrote:So, i signed up to this forum in the hope of purchasing a new engine for my slightly rusted but not terribly dead BMW 316 E30, Planning to put a 325 Carbed engine in it.
- murran
no they didnt.Speedtouch wrote:They did a carb version of the 325?Akumu wrote:So, i signed up to this forum in the hope of purchasing a new engine for my slightly rusted but not terribly dead BMW 316 E30, Planning to put a 325 Carbed engine in it.
but a couple of guys on the e21.net have fitted 325i/2.7 eta engines and run them on capri 3.0 v6 weber carbs. anythings possible!
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
