Does anyone know if I can tow an E30 touring (without powertrain, prop or diff) on one of these A-frame contraptions?
Cheers Guys
Towing with an A-frae
march109
- Contact:
how old are you? can you gestimate the weight withought powertrain, prop or diff? and how far are you travelling?
A frame or dolly?
I have an A-frame that I have rescued many a sad turd with! Locally in the south west and I've even towed one from Dover and another from Manchester, both back to Bristol.
Never had any issue's and have been seen & overtaken by plenty of policemen....
HTH
HTH
Same as above.tomson wrote:I have an A-frame that I have rescued many a sad turd with! Locally in the south west and I've even towed one from Dover and another from Manchester, both back to Bristol.
HTH
Not 100% legit though.
march109
- Contact:
Given that you are all A ok. over 700kg and it is downright illegal.KRAMSSAYB wrote:Hi,
I'm 21, the car weight is approx 700kg, and 100miles.
I thought it was 750? Im pretty sure it is supposed to be braked and for recovery only.march109 wrote:Given that you are all A ok. over 700kg and it is downright illegal.KRAMSSAYB wrote:Hi,
I doubt you'l get an e30 down to that though. We have just
I thought there was issues with 'A' frames due to the rack being in front of the control arm and the frame 'snagging' it's self - where as a towing dolly does the trick as long as it has it's own braking system for weights over 750kg
I'd say be safe, bite the bullet and rent a trailer for the day.
I've not had that issue with mine, if its chained correctly to the wishbones there is no problem.Nelly wrote:I thought there was issues with 'A' frames due to the rack being in front of the control arm and the frame 'snagging' it's self
I wasn't aware of the weight issue though.
At 21 he'll have a 750kg towing limit on his license though. Hence a guesstimate on wight of 700kg gives very little room for error too.Nelly wrote: I'd say be safe, bite the bullet and rent a trailer for the day.
Scruffymurphy
It's not legal, but I've done it myself. I towed a 325 touring over 100 miles using an A frame a few weeks ago. You just need to take it easy and don't brake hard, especially on a corner.
