Hi guys Ive got a 325i se late 91
Should i have a buzzer to let me know ive left
my lights on??? It chimes if the temperature drops below 6 !!!!!!!
If i have where would it be??
Cheers....
Door Chime?????
They weren't fitted as standard, but are quite simple to retrofit. See these threads
http://www.e30zone.net/modules.php?name ... ing+buzzer
http://www.e30zone.net/modules.php?name ... 30&start=0
FlappySocks
- Contact:
I have been thinking about making some up, which will also have an interior light delay, and a moisture sensor. The moisture sensor tells you when you have water under your carpets, which seem to be a big problem amongst zoners recently
Motronic to Megasquirt Plug and Play Guide
