What U got planned for your E30 in 2008
Andy335Touring
- Contact:
I've got an Emerald ECUagent006 wrote:Are you changing ECU for that? Their website says the'll only map their own systems these days.Andy335Touring wrote:Get my engine mapped at Emerald
Get my moneypit Bexley 2.7 engine working in a car again!
Then brakes, and have lots on fun on the track
1. Respray
2. Some form of turbo setup
3. Maintenance
4. Hopefully A Feature?
3. Maintenance
munky30
- 100% Pure Council
take the bulb out.march109 wrote:Fitting all that crap (if and only if it passes its MOT!) Currently I have an ABS problem that doesn't seem to check out, all the sencors work, and I've changed the pump, ECU and relays for known working ones but still the light won't go out!![]()
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
Re shell into a touring that is already under way for the tech 1.
The mummy wagon will be slammed, Scorpion dtm to go on and I have a screen to put in the back to keep Alex happy.
I have a few bit's of bling for the 2 tone tech 2 To make it look nicer on the inside. (If I don't sell it)
Hyperion
1) new brake pads (done)
2) redo front and maybe back suspension rubbers
3) fix buckled rim
4) Service
5) New exhaust
6) Get Koni shocks
7) spray bumpers and front
install the IS lip
9) replace PAS fluid
10) few cosmetic interior jobs
hmmm this might take me the whole damn year...
3) fix buckled rim
4) Service
5) New exhaust
6) Get Koni shocks
Need to replace track rods (came up on last MOT)
Front o/s bearing has been grumbling since December
I'm sure somethings come loose on the arb
Couple of rust patches to fix up
Need to sort engine idle issue, but got spare AFM and TB to try
Though I saw the quote on parts from Zimmer for OE parts...
Maybe when xmas is paid off..
JimmyC
- Contact:
To race it, and enjoy it now all the hard works done
(well until something goes wrong)
www.pbmwc.co.uk
www.pbmwc.co.uk
mick_318is
Sell it
Then a little bit later but another one
Fushion_Julz
There are always a huge list of jobs:
M3:
Run in new engine
Change diff and gearbox oils
once run in, book a re-map to take advantage of new cams
respray rear spoiler
sort out the small rust patch in the drivers' footwell before it becomes a hole
investigate noisy bearing
Touring:
Respray spare sunroof panel in Lachs and fit
Sort out rear wiper (probaly broken wiring)
Remove steering wheel to refurb horn push contact ring
sort out central locking
get to the bottom of alarm power drain
source a new gearknob and handbrake handle and fit
sort out 3rd speed on blower fan
sort out the n/s rear light cluster sidelight (keeps failing to turn on without a "tap")
fit new speakers
source rear speaker pods
325:
sort out the rust spots
fit new n/s front wing (old one is a bit crunchy at the bottom)
make good spare sunroof panel and fit
probably loads more to find and do, too
I also have a few jobs on my Mercedes 609 van, too!!
M3:
Run in new engine
Touring:
fit new speakers
325:
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
DaveGT
- Contact:
Well after picking my cab up a month ago I've already replaced a few bits but there's LOADS more to do, Want the kit on and have it sprayed before Billing
Sort a few bits of rust (In progress)
fit new front wings
Source tech 2 kit (Done)
Get car and kit sprayed
Choose new wheels
Replace bushes
Replace brakes
Next years it's
New hood
Engine Mods
fit new front wings
Choose new wheels
Replace bushes
Replace brakes
Next years it's
New hood
Engine Mods
Health and Safety Officer: "What would happen if a cameraman were to slip over?"
Clarkson: "Well, he'd probably have to stand back up again"
Last weekend i fitted a lower mileage engine and box, with lightened flywheel and z3 gearselector to my 318iS.
Next is to fit a new rear beam with decent bushes, fix all the holes in the exhaust, and invest some money at the bodyshop getting it looking smart.
Oh and trying not to bin it!
Gene_Genie
Fit the b25 engine i am still waiting for transport to pick up.
Replace every bush and ball joint under the car, front and rear.
Convert rear trailing arms for 325 ones that have disc rear brakes
Fit new exhaust
Fit new exhaust
320i - The Joy Of Six.
bmwe30mtech
Already done a complete top end engine rebuild in new head, new headgasket cambelt and waterpump and looooadds of other engine parts replaced.
Still to do, fit:
Two rear quarter panels
Rear panel
Sunroof tray
Scuttle
Rear inner arches
Front wing
Sunroof panel
All bought and ready to drive the car to sheffield to beardymat in the summer. Joys of E30 ownership..
Still to do, fit:
Rear panel
Sunroof tray
Scuttle
Rear inner arches
Front wing
Sunroof panel
tailoutcharlie
get rid,
get another that isn't white, four door and rusty
Chris
StuBeeDoo
Front suspension now sorted.StuBeeDoo wrote:Apart from driving it.....
First job is to get the Recaro's and rear seats all in matching cloth.
Second is to have another attempt at locating knocks in the front suspension (I've already changed everything except the legs and top mounts).
I need to get the scuttle repaired.
An MTech2 front spoiler would be nice.
And hopefully I can get my 2.3 engine project under way.
I think this is the shortest my list has been for the last 4 years.
Making brackets for the SapphCos Recaro's this weekend and the cloth is now on order. The seats should be at the trimmers by this time next week.
I've sourced an MTech2 front spoiler (thanks Tony), I just need to tidy it and do something about blanking the foglight holes.
sort out small rust spots
fit tech 1 kit
get recaro seats finished
fit 325i sport box and diff
smoked lights all round
h and r cup kit
h and r anti roll bars
black out kidney grill sort out crome. ( not sure what im doing with it but doing something)
and maintenance
all if i get enough time and money.
fit tech 1 kit
h and r cup kit
and maintenance
miniblob
- Contact:
My list is never-ending and changes daily, but basically:
More power
Bigger brakes
Carbon Fibre
HID
Interior and ICE!! (The carpet will be dyed black and put back in one day!! And the ice will go in properly one day!!)
Other than that, a circle of fix it break it fix it break it fix it, which will be starting very soon.
And more trackdays and roadtrips!!!
And lots of tyres i would think!!
More power
Bigger brakes
Carbon Fibre
HID
327 Touring with bass!!!
Just changed the water pump, cambelt and tensioner, also radiator. Urgently need to attend to the very lame handbrake, carry out some rustproofing, also learn about Megasquirt so I can competently play with the management system.
well got a new rear qtr fitted last week so im getting there im felling well happyjbh wrote:inner rear arches repaired
drivers rear arch fixed or new qtr
respray ( lachs silver at moment going diamond swartch black metallic )
engine and box fitted
wiring loom changed
interior fitted
roof lining changed
manual sterring rack
front and rear strut braces fitted
spax suspension fitted
new brakes fitted
brake pipes replaced
fuel lines replaced
new bushes all roand
rear beam stripped off and refurbished
and possibly more that cant come to mind the now
god ive got my work cut out
before
after
theres the rear panel after being repaired
shedrool83
Chuck the Goodridge hose kit Gwynelm flogged me on the car,Tax it, wash it and drive....it needs nowt got it as i want it
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......
FlappySocks
- Contact:
For my latest project E30 (Motorsport cab)....
March & April:
Replace some/all bushes
Replace Springs
Z3 Steering Rack
Upgrade/service brakes
Megasquirt
Paint and fit Mtech1 rear bumper, side skirts, and front splitter.
New tyres
May to September:
Fit Stereo/Subwoofer
Drive it
MOT
After September
New roof
Attempt an M30 conversion
WANTED: Side skirts
A few pics so far http://www.flickr.com/photos/-stuart/se ... 2634128569
March & April:
Replace Springs
Z3 Steering Rack
Megasquirt
New tyres
May to September:
Drive it
MOT
After September
New roof
WANTED: Side skirts
Jesus325iTouring
- Frog freak !
Ditto,my poor Sports seats are getting desperatecro320 wrote:new seats if I found decent ones or reupholstery
cro320
- Contact:
still trying to find someone who can fix some rips on driver side, looks bad but upholstery is expensiveJesus325iTouring wrote:Ditto,my poor Sports seats are getting desperatecro320 wrote:new seats if I found decent ones or reupholstery
Le Mans Classic 2006
Motronic to Megasquirt Plug and Play Guide
