Your Best Bodge Pictures
Cypriotgeeza
Mon Dec 16, 2013 11:37 pm
bss325i wrote:Nice E61 tailgate wiring repair!
Rear top mount. ITS STRONG!
This wont short out. Will it?
Now we are talking
Check my M30 build threads:
Cypriotgeeza
Wed Dec 18, 2013 10:03 pm
Had this beauty up on my ramp today at work...Look at this brilliant chassis rail and Nearside front box section repair...Bear in mind this is a 60 plate M3!!!!
8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O
Brake pipes rubbing on the re-inforcement plate! :eek:Image
I instantly got my phone just for this thread lol
pony
Wed Dec 18, 2013 10:25 pm
pacerpete wrote:
TPS wrote:
DanThe wrote: It might have been acceptable on a 50's or 60's BL shitter that would only rev to 4k rpm, but not on an S50
Always wanted an Austin Ambassador, have to see if that works on one of them :D
Ambassadors all had 'modern' OHC O series mills. The earlier Princess had the B series tractor engine*
* Thanks to Andyboy for this gripping BL trivia :)
Hindustan Ambassador of India :-)
Bit of a bodge, but at least the panel is fitted reasonably straight, though they might have been a little more thorough with the welding, and applied some underseal to protect it from rust!
Wed Dec 18, 2013 11:13 pm
Speedtouch wrote:Bit of a bodge, but at least the panel is fitted reasonably straight, though they might have been a little more thorough with the welding, and applied some underseal to protect it from rust!
Really? Its 'straight' so its not so bad??? :mad:
Out of sight, out of mind,,,,,,
I wonder how much they got raped for that bodge? 8O
How much of the car had been repaired out of interest?
harry_p
Wed Dec 18, 2013 11:15 pm
That would fail an mot within a couple of years 8O
I assume it wasn't a bmw approved body shop that did the repairs...
cheers,
harry
capnmchl
I want to know why a 60 plate M3 was being repaired with new chassis rails!?
Wed Dec 18, 2013 11:50 pm
What I meant was, at least a 'proper' panel has actually been fitted on in what appears to be the correct position, and reasonably well welded in (albeit not thoroughly enough). I've certainly seen worse!
For instance, they could have lashed up some home-brew panel of incorrect gauge steel, as many have done...
Thu Dec 19, 2013 12:25 am
capnmchl wrote:I want to know why a 60 plate M3 was being repaired with new chassis rails!?
It happens.
I've seen older less valuable cars get new chassis rails.
Cypriotgeeza
Thu Dec 19, 2013 5:53 am
Yea not sure why it was repaired in the first place but genuine panels 100% NON GENUINE repairer
The pics must be doing it a bit of justice because that is a horrendous repair mate! Brake + fuel pipes rubbing on the plate 8O plus some of it is just tacked in place!
That was the only bit that was repaired basically all the N/S front lower section
Thu Dec 19, 2013 9:33 am
It looks like its hanging off to me!
Cypriotgeeza
Thu Dec 19, 2013 10:22 am
DanThe wrote:
Speedtouch wrote:
DanThe wrote: Really? Its 'straight' so its not so bad??? :mad:
Its not far off..the closest part to the wing isnt welded at all!! :o
Thu Dec 19, 2013 11:10 am
harry_p wrote:That would fail an mot within a couple of years 8O
I have seen plenty of nasty workmanship leave a BMW approved bodyshop..........
Thu Dec 19, 2013 11:16 am
I had to repair a Peugeot 306 Cabriolet this summer, where some jackass had fitted the wrong size balljoint to the driver's side lower wishbone (they are available in 16mm and 18mm), and it kept popping out of the wishbone when the steering wheel was turned. :eek:
The bodger that had fitted the undersize ball joint then used some crappy bit of wire wrapped around it to hold it in - potentially lethal if it had popped out at any speed! :roll:
Thu Dec 19, 2013 11:27 am
Speedtouch wrote:I had to repair a Peugeot 306 Cabriolet this summer, where some jackass had fitted the wrong size balljoint to the driver's side lower wishbone (they are available in 16mm and 18mm), and it kept popping out of the wishbone when the steering wheel was turned. :eek:
That should have been a warning to you but no, you persevered with the sorry Gallic spastic and now the engine is scrap :(
They are cheap and unwanted for good reason ! :)
Thu Dec 19, 2013 11:29 am
True! Oh well, you live and learn...
Fortunately, I only paid £450 for the turd, and did at least enjoy some swish topless Pininfarina style before the knicker elastic let go. :)
pony
Thu Dec 19, 2013 12:53 pm
Tell us more you can't leave it that ?
andyp
True Old Skooler
Thu Dec 19, 2013 1:04 pm
I have seen plenty of nasty workmanship leave a BMW bodyshop in Ivor Heath..........
I am sure you have, saying that how is the Toyota ?
