springs/shocks better then Mtech ones...
Dan318-is
Post Tue Mar 14, 2006 6:59 pm
no but i have some koni shocks on my turd outside, 46mm ones tht will go on urs! ( i think)
dark_sounds
Post Tue Mar 14, 2006 7:02 pm
koni's any good?? didnt someone say they bit harsh on the road??
Kos
Post Tue Mar 14, 2006 7:03 pm
toby wrote:
Kos wrote:billies with proper springs, H+R / or the ones supplied by ECP in the street/sprint line kits. got them on the 316 and the IS
konis are ok, but a bit oo harsh for the roads??
kos has a good pint here.
"The Bilstein Streetline Suspension Kits Product code: BSK116
Bilstein Streetline Suspension Kit. Lowers by 40mm approx.
The Streetline kit consists of four Original Equipment (OE) Spec Bilstein Gas shock absorbers complete with lowered sports springs. This Entry-Level kit proves very good value for money. Ԛ£207.00 (inc VAT)"
http://www.europerformance.co.uk/pages/ ... ml?id=2966
Can you use the Bilstein Streetline Suspension kit on a touring ??- I'm assuming you can't
the shocks you can, the springs differ in poundage, the 40mm drop in the sprin/street kits can make it too low at the back, so on my 316i i acdded m-tech springs from the IS to brig it up slightly.
there is a similar thred to this one going on at the mo,
as a point of interest, i'm looking at KW springs at the mo.
Dan318-is
Post Tue Mar 14, 2006 7:04 pm
they are a tiny bit harsher i think, tim_s runs them on his daily an says they do the job tho!
will be a cheap set for all four tho and springs too!
dark_sounds
Post Tue Mar 14, 2006 7:07 pm
what drop??
Kos
Post Tue Mar 14, 2006 7:10 pm
KW list 55/35 for the IS, the do complte kits aswell.
Dan318-is
Post Tue Mar 14, 2006 7:16 pm
Ali you got PM
dark_sounds
Post Tue Mar 14, 2006 7:50 pm
tbh im just after a drop approx 40 mill from factory,,, and a smooth ride,, i dont want a bumpy sporty ride,,, its still my daily driver, but just want the pimpin looks.. unfortunatly theres no chance getting away with 60mm :(
Post Tue Mar 14, 2006 10:52 pm
well the boge 40mm's from gsf will be for u then, and at around Ԛ£60 won't break the bank!
