What Have You Done To Your Car Today
mark_i
cleaned out airvents with toothbrush and gave Tech1 a clean and feed.
paultv
Today my vert got fresh oil and a new filter - one of the only ones with a non return valve, like the original oem filters had, but non of the options available now are fitted with.
So, now my oil light vanishes after half a second instead of 5 seconds which can't be good for the engine.
Paul
Paul
Satan
The wife's I hope when she was out.......mark_i wrote:cleaned out airvents with toothbrush and gave Tech1 a clean and feed.
Satan
Yesterday didn't happen, today though 12v to 5v USB adapter installed and........ bonnet insulation replaced which has sat in the loft for 4 years..........
Oh and fed the leather for the rear backrest.
realised my mot is nearly expired , this means i get to drive it soon
+ a yard full of scrap turds
Satan
Lol, to the MOT centre and back...........
it needs an mot for the Scottish car show july 15th ... we got 30 e30's on the stand
Satan
1 E30 transporting 29 toasters........
you'll be surprised when the pics are upSatan wrote:1 E30 transporting 29 toasters........
Bonymaenjack
Installed a Bavaria 3 Reverse 111 radio cassette along with Hirschmann aerial .Nice
Steve
Sump gasket, wishbones, lolipops, droplinks done.
Ready for MOT on Saturday
webmaster@e30zone.net
billyfrost
Rebuilt the nearside front suspension, new everything basically - most rotten E30 ever! Other x3 corners to sort next...
Satan
Had to lol at the Hi Mileage bit........paultv wrote:Today my vert got fresh oil and a new filter - one of the only ones with a non return valve, like the original oem filters had, but non of the options available now are fitted with.
Paul
Satan
Need to check today to see if the foam is still attached to the bonnet or just sat on top of the engine.
new foam is £55 ish from oem parts on here .Satan wrote:Need to check today to see if the foam is still attached to the bonnet or just sat on top of the engine.
ah
What did you use to feed your leather with ?Satan wrote:Yesterday didn't happen, today though 12v to 5v USB adapter installed and........ bonnet insulation replaced which has sat in the loft for 4 years..........
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
Satan
I use Gliptone's Liquid Leather,
https://www.liquidleather.com/?gclid=Cj ... UgQAvD_BwE
I do feed the seams on a regular basis on the backrest as that section has a tendency to dry out and shrink then the seams go.
paultv
Did your bonnet insulation stick? was it pre-glued or did you spray on?
Mine looks OK but doesn't stay stuck in hotter places despite new glue.
Paul
Paul
Satan
The left and right side stuck on but the centre section was a bit "awkward" I suppose years in the loft didn't do it any favours and I really need to check to see if its still stuck on and not just sitting on top of the engine.paultv wrote:Did your bonnet insulation stick? was it pre-glued or did you spray on?
Paul
The bits that didn't stick I used some 3M spray glue for foam.
https://www.vikingtapes.co.uk/products/ ... 4688199367
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Drove it to work. Stefan, what alarm system have you got on your car and how does it operate? eg: does it operate when the roof is down?
Gert_8
Satan
Sent you a WhatsApp.Gert_8 wrote:Drove it to work. Stefan, what alarm system have you got on your car and how does it operate? eg: does it operate when the roof is down?
Come on mate, tell us all......................Satan wrote:Sent you a WhatsApp.Gert_8 wrote:Drove it to work. Stefan, what alarm system have you got on your car and how does it operate? eg: does it operate when the roof is down?
I may be passing yours very soon.lol
Steve
Took the E30 for a MOT this morning, passed, no advisories.
Living the dream SteveSteve wrote:Took the E30 for a MOT this morning, passed, no advisories.
Started her up yesterday for the first time since February , no issues here
