Brake bleeder, anygood?
Kos
Post Sat Jan 17, 2015 1:30 am
Demlotcrew wrote::cool:
Its an old F1 bleeder, it basically drains and drys the brake system, then pumps in new fresh fluid. Its pretty neat as it does both sides of multi piston callipers as well as front and rear circuits at the same time, makes bleeding a joy! No messing, all dry break fittings (calliper dependant).
Heres a better photo.
Andrew
Jesus f-king Christ Andrew 8O :D :mad: :cool:
www.pukardesigns.com
IG Pukar.Designs
powelly
Post Sat Jan 17, 2015 8:57 am
Image Le Mans Classic 2006
powelly
Post Sat Jan 17, 2015 9:01 am
diable wrote:Is the air bubble in the gauge there to make sure the unit is level?
I doubt it, it's probably just a liquid filled guage, they help stop vibrations affecting the needle readings, Basically it's a method of damping.
Demlotcrew
Post Sat Jan 17, 2015 9:06 am
That's right, it's just they are liquid filled as they are simply better.
http://www.wika.us/Liquid_Filled_Gauges_en_us.WIKA
Andyboy
Alpina Colada
Post Sun Jan 18, 2015 8:38 pm
50psi may just flip the seals in the master cylinder. 20 psi should be plenty and the Gunsons one uses about 15 psi.
Demlotcrew
Post Sun Jan 18, 2015 8:50 pm
Eh?
Post Sun Jan 18, 2015 9:06 pm
To bleed DSC units with the BMW diagnostic system you need 2 bar so just under 30 psi.
Demlotcrew
Post Sun Jan 18, 2015 9:13 pm
DSC bleeding is a pain on stock turds, try that on multi piston callipers and bias twin cylinder setups, real head ache!
BROOMY
busy saving Clifford
Post Tue Jan 20, 2015 7:35 pm
Funny this thread popped up
Today was working at someone's house and spotted this.
