yes !!!!Junglistjed wrote:will this be enough? > http://www.ebay.co.uk/itm/WAXOYL-under- ... 1449wt_886
and as for the fertan, this stuff? > http://www.ebay.co.uk/itm/Fertan-Rust-K ... 19df4555d9
Will stick it in the garage this weekend if these arrive on timebeen really rainy here so want this done asap
thanks for the replies guys
the fertan- is a rust treatment and prevention, put some in a squirty mist type spray bottle- and spray it as i said above in them rear arches inside, and inside bottoms of doors
sills- remove the top long black sill trim protector to reveal the holes, block up the dranage slits underneath, but be careful it can be removed, then pour and spray the fertan all in there as much as you can at all angles, just to get at any rust hidden in there etc, and pour down sunroof drainage holes too - you can put a tub underneath to catch and re use the fertan as it drains out-repeat,repeat
also you can pull off the plastic scuttle vents- spray it in there in the corners and runs is very beneficial in long term protecting
then , waxoyl all them areas a day or 2 later, should see the cars inner cnooks and crannies well protected
tbh every e30 should have this done for the sake of a few quid and a couple of hours work, very beneficial
Le Mans Classic 2006
