snapped lollipop bolt in chassis HELP!
BATTS91
Sun Jan 29, 2012 4:05 pm
well i have a solution but requires drilling the coont out and the drill a hole in the floor to get to the hole and put a nut and bolt through and drive it dwn to my pals and weld the nut in and obv the hole too :/
rhubarb
Sun Jan 29, 2012 4:49 pm
What you need is some proper heat, then it will come straight out..oxygen acetylene is what is needed.
Google for a local mobile mechanic, and ask then if they have got the right gear, should only charge you an hours labour :)
Sun Jan 29, 2012 5:19 pm
BATTS91 wrote:well i have a solution but requires drilling the coont out and the drill a hole in the floor to get to the hole and put a nut and bolt through and drive it dwn to my pals and weld the nut in and obv the hole too :/
Last resort this. Don't do it unless absoloutley no other way.
I'd be hiring an oxy kit and getting the stud cherry red!
manse73
Sun Jan 29, 2012 5:28 pm
dewalt extreme drillbits and be patient with it
if you think it will go wrong as you do it the job will go wrong
think positive and show the car/bolt who is boss
bruv chariots rule
cecotto479
Caution Unreliable Seller
Sun Jan 29, 2012 6:21 pm
Ideally you don't really want the stud cherry red, you want the captive nut heated as hot as you can get it. Loads of plusgas. Loads of heat. More plusgas. More heat. Mole grips or stillsons. It'll definitely come out. An oxy turbo mapp gas kit hired or borrowed will do it.
1981 E23 735i
bodger
Sun Jan 29, 2012 7:24 pm
rhubarb wrote:What you need is some proper heat, then it will come straight out..oxygen acetylene is what is needed.
/\ this
BATTS91
Sun Jan 29, 2012 7:48 pm
right if i go for the oxy acetylene route any other tips , the last thing i tryed today was mole grips and because i drilled a hole in the centre one side of the bolt has caved in so getting it hot wouldnt this make it even weaker and the part of the thread showing snap off ? may make a call to tool hire shop tomorrow see what happens
BATTS91
Sun Jan 29, 2012 8:07 pm
its either that or hire a welder and try welding a nut on and while im at it minor rust repair :/
Sun Jan 29, 2012 8:53 pm
Gas axe FTW :)
chh137
Sun Jan 29, 2012 8:57 pm
BATTS91 wrote:its either that or hire a welder and try welding a nut on and while im at it minor rust repair :/
thats the answer
Dezzy
CR24v it's a lifestyle
Sun Jan 29, 2012 8:58 pm
Don't heat the stud! That will make it worse.
The captive needs the heat, getting it hot safely is another matter.
Drilling it out is the safest way IMO. It won't be much fun though.
If the shell has rust issues anyway, would you be better off scrapping it?
Sun Jan 29, 2012 9:01 pm
BATTS91
Sun Jan 29, 2012 9:19 pm
its not that bad of a shell actually just the usuaral box section has gone and a jacking point nothing really ive seen a hell of a lot worse repaired think ill try renting a welder , never used oxy so stick to what i know and can use
Sun Jan 29, 2012 9:24 pm
Could you not replace the lollipop with just the one bolt (the snapped one will serve to locate it) and gently drive it to a place where you can get a nut MIG-welded onto it?
I've usually found that stuck bolts will usually succumb to the red-hot heat from local MIG-weld.
I had a 1992 Ford Orion with a totally jammed in wishbone bolt with a rounded-off head, and MIG-welded an old broken socket drive bar to it, which shifted it.
Dezzy
Sun Jan 29, 2012 9:29 pm
Speedtouch wrote:Could you not replace the lollipop with just the one bolt (the snapped one will serve to locate it) and gently drive it to your local weigh-bridge
EFA winkeye
Sun Jan 29, 2012 9:39 pm
:eek:
Sun Jan 29, 2012 9:47 pm
In situations like this, even a cheap MIG welder comes in very handy - can you not hire or borrow one locally?
mrb27
Sun Jan 29, 2012 10:02 pm
Uploaded with ImageShack.us
saved my ass many times these :D
rhubarb
Sun Jan 29, 2012 10:15 pm
scrap it over a snapped bolt ffs??!! :eek: :roll:
BATTS91
thats for rounded off heads bud the bolt head sheared off ,
dezzy you take the pish i bet your turd has rust lurking the all do at some point the getting old well they are old, it was'nt so bad when i bought it but being on the driveway almost a year in all this shite wether hasnt done me favours water just sitting on it not running of in daily useage
i think my safe bet is rent a welder i think the local charges £30 inc delivery a day may have a look see if theres some cheap mig welders about for sale local
BATTS91
Sun Jan 29, 2012 10:17 pm
rhubarb wrote:scrap it over a snapped bolt ffs??!! :eek: :roll:
over the stance thread issues dont think he likes my car lmao
rhubarb
Sun Jan 29, 2012 10:20 pm
I see, haven't read that thread, shall have a nosey :)
Sun Jan 29, 2012 10:23 pm
Have a look, make your views noted, plenty others have, free speech etc :D
Dezzy
Sun Jan 29, 2012 10:25 pm
I'm only offering you the benefit of my vast experience. It sounds like I'm on a wind up, I'm not.
Have a look at any of the resto threads on here. There is loads of them. Most started with a couple of small rust issues.
X10 what you can see and you'll be somewhere near :(
redcar
Sun Jan 29, 2012 10:29 pm
x20 will bring you closer :P
BATTS91
Sun Jan 29, 2012 10:42 pm
my cars no minter but its not a rott box either im not going to lie about it no need , there the passenger floor around box section usuaral place drivers jacking point slight bubble on rear valance , boot seal tiny rust and a pin hole in scuttle some may say its major but in reality and actually looking at it in the flesh its fook all ive seen on an e30 rear arches are fine which is a suprise , the car started life as a 318 is and mow m50 powered
mrb27
Sun Jan 29, 2012 10:55 pm
BATTS91 wrote:thats for rounded off heads bud the bolt head sheared off ,
na m8, ive pulled many a studs out with em winkeye
johnl320
Sun Jan 29, 2012 11:02 pm
One method we use at work is heat the stud for quite a while, this heat would transfer into the nut. We then rapidly cool the stud/bolt using a can of air duster turned upside down to make it contract then quickly try to work it loose usint mole grips/ pipe wrench etc. Didn't work every time but worth a try.
rhubarb
Sun Jan 29, 2012 11:45 pm
DanThe wrote:Have a look, make your views noted, plenty others have, free speech etc :D
done :)
Bet the red one, would stuff my back in within a mile :wink:
redcar
Mon Jan 30, 2012 6:48 am
done :)
BATTS91
Mon Jan 30, 2012 2:19 pm
anybody got opinions on a 130amp mig welder seen one today in local panel shop not sure of make not a known one was £150 tho
Mon Jan 30, 2012 2:22 pm
Should be more than ample for the job. I use a Clarke 90EN (90 Amp) no-gas one, and it's fine for stuff like this.
You can pick them up second-hand for far less. Be sure to test them first though, as the wire feed rollers tend to wear (they are replaceable). SIP ones in particular have a poor design of wire feed.
BATTS91
Mon Jan 30, 2012 2:38 pm
just called them up its a siegen 130amp mig gas welder i got off the phone and straight away thought i should have asked if it was +vat as most of there stuff is
BATTS91
Mon Jan 30, 2012 2:45 pm
a little google on reviews show its made by sealey which is good , and an overall good base welder in comercial use may be buying a new welder instead of tax and mot this month and get alot of welding done i suppose
redcar
Mon Jan 30, 2012 3:39 pm
Sealey Supermig is the one you want :)
