How easy is the e36 window switch mod?
smithy318i
Post Thu Mar 30, 2006 12:23 am
sent to neil
nadz325i
Post Thu Mar 30, 2006 12:36 am
here you go lads, have fun 8) :D
http://www.strictlyeta.net/technical/e36switches.html
this mod is fantastic, much better than those standard ones.
call breakers up, visit breakers,
early model e36 switches non one touch WHITE base, there 2 different colour looms on some models, dosent matter as long as the switch is white base non one touch. also get switch base with 3 -4 inches or the loom intact.
cut the e30 base off, and wire them up accordingly.
****please please test the circuit/wire connections, dont want to hear about e30 caught on fire or anybody hurt!! if your not clued up with electrics i wouldnt recommend this.
we used that article do to my converison, but we only used the wiring connections as a guide, we opened up the switches and found out how they worked (up,down) and wired them accordingly to the e30 loom..
all in all a very good conversion :cool:
would post up pictures of the wiring connections but i havent got my e30 at the moment, if i get it by the weekend i post some pictures. 8)
Dan318-is
Post Thu Mar 30, 2006 1:08 am
tylerma wrote:
Ceeman wrote:Trouble was, most of the motors from the scrappy were the same or soon would be, and a new one was approx 180 quid, utter crap.
thing is mate its not the motors you change
its the just the switches
and it will be a reversible mod
so you will be able to go back to original if you wanted/needed
So bye just changing the switch i can have one touch window switches?
Chaos
Post Thu Mar 30, 2006 1:31 am
nadz325i wrote: would post up pictures of the wiring connections but i havent got my e30 at the moment, if i get it by the weekend i post some pictures. 8)
cheers for the article link, and also the wiring connections wud be very useful - ta. :)
Chaos
causing havoc and mayhem wherever i go
Demlotcrew
Post Thu Mar 30, 2006 7:49 am
They dont look that bad but i dont think its something i will be doing.
Andrew
t11mfn
Post Thu Mar 30, 2006 10:26 am
does this mod give you the one push up and down that modern cars have?
dazleeds
old skool raver
old skool raver
Post Thu Mar 30, 2006 10:32 am
t11mfn wrote:does this mod give you the one push up and down that modern cars have?
no its simply a button swap
im sure you can also add the 1 touch relay from an e36 set up but this would mean some additional wiring
sorry dnt have a guide with the 1 touch
www.oldskoolfantasy.co.uk
stevetigger
Post Thu Mar 30, 2006 5:37 pm
Im going to do this seeing as I have a convertible with four electric windows and a bloody hood thats electric! Would make putting the roof down ten times easier. winkeye
