CALLING ALL 318IS DRIVERS, WHATS YOUR 318IS LIKE ON FUEL
Mon Apr 26, 2010 3:10 pm
i find my obc accurate?
is it setup for the correct fuel tank too
Ant
Retired Team Member
Retired Team Member
Mon Apr 26, 2010 3:12 pm
44 is calculated from fuel in vs miles done , simples :thumb:
no wind up, hard accel to 80 then 80 everywhere until I come off the motorway( approx 3.8 miles non M-way on my commute BTW )
Royalratch
Mon Apr 26, 2010 3:16 pm
My 320d does 30MPG 8O
I'm assuming it;s because I do all central town miles, stop start 1st gear only and no journey longer than 5miles / 20mins.
This pi55es me right off.
Jon_Bmw
Dangerous when thinking
Mon Apr 26, 2010 4:51 pm
Ratch my iS never had an OBC. It was always calculated properly, brim to brim none of this tenner here, 2 quid there BS.
I always got 32 mpg out of mine however I drove(within reason), although it is worth noting I couldn't get much better than 34mpg no matter how nicely I drove. I put that down to the 4,10 diff and high revs on the motorway.
Seriously it is a 1.8, if you are getting 22mpg, get something with a bigger engine and enjoy the performance for the same cost. Alternatively FIX the problem it has obviously got. Incidently, my 540 does 24mpg mixed driving. More on longer runs.
Your 320D never warms up, that MPG isn't suprising. A small engined petrol might be just as good if it only did that 5miles a day, but I doubt that is all it does.
Royalratch
Mon Apr 26, 2010 5:30 pm
I'm ditching the 320d for an another E46/E90 petrol 6 as I know Diesels need to warm up and are useless as city cars.
I should just get a 1.6 Golf but I could never do that.
My iS gets about 30MPG in town but having just read above, how is Ant getting 44MPG???
tez180
Mon Apr 26, 2010 5:31 pm
Ant wrote:44 is calculated from fuel in vs miles done , simples :thumb:
Yipz,
My IS also likes sitting at 80mph... i know its not accurate but the fun meter is always reading 45+ at that speed. odd.
Accord Type R
245 Whp
polsta
Mon Apr 26, 2010 5:33 pm
Yipz,
mines exactly the same, loves sitting at 80 or 90 and cruises along lovely
Royalratch
Mon Apr 26, 2010 5:35 pm
The OBC is nonsense but as Ant says he'd one the correct fuel/miles calc then that is incredible.
Mind you, I'm only going by OBC too so I should do a brim-to-brim and see what happens.
Mon Apr 26, 2010 6:17 pm
my 5 litre test was an experiment. i put half a tank to 3 1/4 in as i don't need to carry a full tank of fuel around every where i go simples i'm not a cheap-skate who puts £7.50 in hoping to get 100 mile return.
ETERNITY
Mon Apr 26, 2010 7:46 pm
Ant how are you getting 44 mpg
what mods have you done to acheive this mpg
adit
Mon Apr 26, 2010 10:59 pm
magpie wrote:per tank-
no mate, i meant miles per tyre! (esp your rears!) :snigger:
:chuckle:
[quote="bss325i"]
Aubs
Aka Mr_Gerbic_iS
Mon Apr 26, 2010 11:18 pm
I was getting around 32-34mpg from mine, properly calculated from a full tanks usage.
ETERNITY
Thu Apr 29, 2010 12:26 am
what about chiping the is.does that decrease economy. Anybody running an evolve chip and what mpg are you getting since using the evolve chip
Thu Apr 29, 2010 8:12 am
:lol:
Ant
Retired Team Member
Retired Team Member
Sat May 01, 2010 8:29 pm
48.7mpg on the last £30
I only ever fill the tank 1/2 way, no point wasting fuel lugging too much around, with fuel so readily found there.s no need to carry more than 200 miles worth IMHO
30 litres of fuel is heavy :lol:
TheHeap
Sat May 01, 2010 10:07 pm
My e36 318is does around the 30 mpg mark but i wouldn't like to sit at 80-90 though as it seems to sit at 3800-4000 rpm. Mind you it will pull all the way to its limit rather enthusiastically. It's not worn out either as it's only got 88,000 miles on the clock and i have had it for nearly 3 yrs.
Oh and i have a question for ya, does the chain need adjusting? I ask this because when i serviced it last week i noticed some sort of plunger that looked to be an adjuster for the chain.
Royalratch
Sat May 01, 2010 11:43 pm
Ant, that figure is physically impossible and better than BMW's standard quote for a modern 2.0 Turbodiesel.
Stop lying.
Sun May 02, 2010 12:08 pm
TheHeap wrote:My e36 318is does around the 30 mpg mark but i wouldn't like to sit at 80-90 though as it seems to sit at 3800-4000 rpm. Mind you it will pull all the way to its limit rather enthusiastically. It's not worn out either as it's only got 88,000 miles on the clock and i have had it for nearly 3 yrs.
undo the 19mm bolt cap on the front left side of the engine and a chain tensioner will pop out.you can get a replacement from bmw for £35 and it will be an m44 one [same as m42 part]
TheHeap
Sun May 02, 2010 12:19 pm
Magpie. Do you reckon it needs doing at this mileage? It doesn't rattle or anything and is it as simple as old out, new in? No locking of timing gear or anything like that? Does the tensioner load up with oil or is it just sprung?
Cheers by the way. :thumb:
Sun May 02, 2010 12:28 pm
it will load up with oil m8,i'd change it to play safe.
yes it's old one out, new one in easy 8)
TheHeap
Sun May 02, 2010 12:33 pm
Thank you sir.
Oh one more thing. Do they all have LSD?
tez180
Sun May 02, 2010 12:34 pm
No they do not.
Accord Type R
245 Whp
TheHeap
Sun May 02, 2010 12:37 pm
Oh right, i only asked because the only time the back has stepped out is when it snowed.
JWaller360
Mon May 03, 2010 4:51 pm
Right - apparently my iS does 40+mpg, which I struggle to believe, but thats what an Internet calculator gives me:
Rationale: £30 @ 119.9/L = 25.02 litres, 230 miles on this much apparently equals 41.79mpg?
Which sounds ridiculously high to me.
ChrisiS
Mon May 03, 2010 9:29 pm
Mine on 213,000 miles typically does 34mpg, I have seen 38mpg on a run, whats more surprising was that on the run I had two kayaks on the roof, and the car was fully loaded with my kit!
Its currently around 32mpg as i have only been doing short journeys of late
ETERNITY
Thu May 06, 2010 1:04 pm
Is yours standard chrisIs
I think using chips must reduce economy.
Who uses an evolve chip on here and has there seen any differance in economy aftering using the chip.
