Calling all 325i owners....
gooner1
Out humping Reindeer
Fri Apr 16, 2010 10:58 am
07/1986.
256E1.
Slightly irrelevant, but pretty sure the Realoem build date is not
100 % accurate, i say this because i have reaon to believe
the above date is my cars registration date, not the 05/1986 build date
i was previously given.
RM2186
Fri Apr 16, 2010 12:12 pm
Barry,
Of the 3 I have :
Build 9/89 256K1
Build 6/87 256E1
Build 12/88 No such code, built in South Africa
1987 Tech1 325i Sport
leeparkes
Fri Apr 16, 2010 3:40 pm
leeparkes wrote:Mines March 88 and i know the code on the plate is 25 6E but will check tomorrow if its 1 or 2
The engine did feel more 'perky' than the normal run of the mill later M20's
Im interested :)
Its 25 6E 2
Fri Apr 16, 2010 8:17 pm
AussieM20 wrote:256K1 October 1987. Original Australian Delivery Car, With Cat
Thats interesting, a very early 256K1. What were the emitions regs for Australia back then? Were cats mandatory?
Fri Apr 16, 2010 8:19 pm
Im interested :)
Its 25 6E 2
Yours is the latest 256E2 so far. Anyone else have one later than this?
Fri Apr 16, 2010 8:20 pm
gooner1 wrote:07/1986.
256E1.
Realoems date is deffinately not reg date.
who gave you the 05/1986 build date?
e301988325i
Fri Apr 16, 2010 8:34 pm
Im interested :)
Its 25 6E 2
e301988325i wrote:'E' reg, build June 1988, 256E2
Mine does go well and I previously understood it to be one of the first facelifts with a HC engine and 1.3 motronic, but also the earlier worm drive electric window system.
I said:
e30topless said:
lock the wife in there
Fri Apr 16, 2010 8:40 pm
Woops. So 6/1988 is the latest now which incidently according to the etk is when the 9.4:1 comp ratio piston was used until but confusingly the etk states 256E2 engines from 9/87 with no cut off date.
gooner1
Fri Apr 16, 2010 9:08 pm
256E1.
Got it from a Spec sheet from the Dealers, about a month
after getting the Cab.
Has Build date 05/1986.
Registration date. 07/ 1986.
Of course the Spec sheet could always have been wrong,
as i say it,s slightly irrelevant. Will ask the Dealer, next time i,m
there , to double check.
Fri Apr 16, 2010 11:40 pm
gooner1 wrote:
256E1.
Thats very early cabby. When did they first come to the UK?
b17
Fri Apr 16, 2010 11:43 pm
256 E2 - mine's a 1988 325i cabby. Build date as stated January 1988. So could mine be a high compression?
blackcountrybimmerman
Sat Apr 17, 2010 12:08 am
Will post tomorrow.....
It doesn't look like it does in my sig pic anymore
AussieM20
Sat Apr 17, 2010 2:55 am
Cats were mandatory as of January 1st 1986 in Aus in conjunction with Unleaded Petrol for passenger cars.
gooner1
Sat Apr 17, 2010 4:43 am
Blitz wrote:
gooner1 wrote:
bss325i wrote: Realoems date is deffinately not reg date.
Early1986 Mo, think the first ones were on a C plate.
AlpineAde
Sat Apr 17, 2010 8:53 am
Barry, February 1986 found cats compulsory on Australian and Australian delivered cars.
aeberbach
Sat Apr 17, 2010 9:05 am
256E1 here - no cat, no O2 sensor either. Motronic 1.0!
Sat Apr 17, 2010 9:52 am
As promised.....
07/1989 G reg....256K1
But I know it hasn't got a catalytic convertor.
Last edited by blackcountrybimmerman on Sun Apr 18, 2010 9:39 pm, edited 1 time in total.
TPS
Sat Apr 17, 2010 11:38 am
02/1991 325IA H Reg, 256K1, this Touring has got a Cat. fitted.
Whats the other numbers on the VIN plate mean, theres a headlight symbol with 1.0 written beside it, & another number written above it?
andyp
True Old Skooler
Sat Apr 17, 2010 6:34 pm
b17 wrote:256 E2 - mine's a 1988 325i cabby. Build date as stated January 1988.
SNAP mine is the same
256E2
jan 1988
cab
BadDave
Sat Apr 17, 2010 6:58 pm
256 K1 on an F (88') touring Barry
toecutter666
Sat Apr 17, 2010 8:28 pm
Build date 06/1990 code 256K1 325i manual cab no cat
Tedswagon
Sun Apr 18, 2010 9:27 pm
build date must be 1987 as it was first registered Jan 1988 (E reg). The code reads 256E2
Will read code under bonnet when I'm next at the car. Currently parked a couple of streets away!
e301988325i
Sun Apr 18, 2010 9:36 pm
Tedswagon wrote:build date must be 1987 as it was first registered Jan 1988 (E reg). The code reads 256E2
Hi, good to meet you today, my car was built June 88, after all they only had to ship them from Germany once built!
I said:
DmcL
Sun Apr 18, 2010 11:30 pm
seems like mine is a bit of a mish mash of early/late.
engine is 256K1 but there is no cat and also no lambda sensor. it runs tronic 1.3 and the vin numner is the old style with all numbers and no letters. 13 button OBC, full electrics and pop out rears, etc.
build in late 88 but first registered early 89.
saying all of that tho.. since converting the car to 5 speed manual it does go alot quicker than u would think for only having servicing/maintenance items done and a handfull of mods. only mods are a chip, home made intake, Z3M gearstick and a backbox. i believe its got a 4.10 diff since it was an auto and i retained the diff but i have never checked the diff out to see.. 5th gear is only slightly above 1:1 ratio. goes like stink for whats done to it tho.
WMMotorsports
adz79
Mon Apr 19, 2010 7:11 pm
Mines got a build date of 04/88 and its a 256se2.
So does this mean its a high comp engine?
bigsheen
Mon Apr 19, 2010 11:20 pm
The_Diddler wrote:I'll post up tomorrow, i took the plate off in preparation for the resto, its in a safe place, hence why i cant find it :(
august 1990 256k1
cube320
Tue Apr 20, 2010 11:55 am
March 1989 256k1
No cat. So the 1 means i have a high comp engine?
Tedswagon
Thu Apr 22, 2010 2:25 pm
10/1987 E30 325i 2 doors M20 Europe Right hand drive Manual
mineralblue
Rocking Horse Poo
Thu Apr 22, 2010 6:07 pm
Right, my min blue cab build date Nov 87 registered Jan 88 is a 256E 2.
I get the impression this is reasons to be cheerful?
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Thu Apr 22, 2010 6:25 pm
Build Date Jul 1990 (Wk30)
25 6K 1
No cat
Taylor.
HairyScreech
Thu Apr 22, 2010 7:24 pm
iv got an august 88 engine on a pallet from a touring, its 256k1.
im thinking its only saloons that will be E1 right?
Fri Apr 23, 2010 11:52 am
Right, it transpires that,
256E1 compression ratio of 9.7:1 (early motronic)
256E2 Compression ratio of 9.4:1 (late motronic)
256K1 Compression ratio of 8.8:1 (late motronic, cat prepped or with a cat)
For UK cars,
256E1 sept '85 to sept '87
256E2 sept '87 to june '88
256K1 june '88 to end of production.
Fri Apr 23, 2010 11:53 am
HairyScreech wrote:iv got an august 88 engine on a pallet from a touring, its 256k1.
Body type has no bearing on this.
beemerbird
Fri Apr 23, 2010 12:00 pm
Another 256E1 from 12/86 for your collection checking in :wink:
