318is chips
My markD chip gives me 5hp extra. (tested on the same rolling road, with five minutes in between).
Don't know if that rolling road is any good actually, and the same goes for the chip. My previous engine went down after I did the timing chain and installed the chip. Still not sure if it was the chip or not. (has an oil pressure problem, makes a diesel sound now
Most Is's are like that i think, you can fell that drop and when it comes in too. Its fooking annoyingJon_Bmw wrote:Old thread alert, but that is some strange torque 'curve' on both Alex and Micks cars.
gareth
it seems to be 120lb.ft down on torque at that point too
that is a big dip though on any engine, do they all do this?
e301988325i
That dip makes it feel faster when it comes on cam
I said:
e30topless said:
lock the wife in there
I hae been trying to find a dyno graph of my old one, but it is on a different computer I think. I don't remember that dip, and I can't really think of a good reason why it is there...
I think it is the scaling of the torque graph making it look worse than it actually is. But the numbers are so blurred it is hard to tell.
I am able to supply a 318is chip, as long as your original BMW chip number is 1 267 356 378.
Fellow Zoner treeseries tried one on his H-reg 318is, and reported good results.
The new chip gave a 7,000rpm rev limit.
to be fair you need a before and after dyno, i thought we might have had access to the dyno all day kind of thing, and i would have brought along a panel filter and the stock chipmagpie wrote:yes from 136bhp up to around 152bhp+polsta wrote:interesting reading
should i bother chipping my is ?
get ya purse out!
Ps: dont forget them injectors today
Speedtouch wrote:I am able to supply a 318is chip, as long as your original BMW chip number is 1 267 356 378.
get ya purse out!
how can i check if its been done already if it has/check what chip number i have ?
already have a k&n filter in the car but have no idea if it has been chipped or standard or what
PM sent.
i have the viper chip definately noticed a noticed a difference although it isnt a turbo'd car so you cant expect much.
is it worth getting an aftermarket filter then?
318is
original ac schnitzer 16" wheels
original oem IX coupe bodykit
aftermarket mod: viper fast road chip
aftermarket mod: clifford intellistart + dual zone
car for sale soon!
car for sale soon!
Only after market filters to concider are the panel ones.
Cone filters, unless done right, don't help, apparently they even make the car lose power.
Not heard that one before.Alex wrote:And apparantly panel filters dont filter properly
What side effects does it give for not filtering properly? Shite making it's way into the engine?
Yes, i'am sure it was brianmoore who mentioned itJozi wrote:Not heard that one before.Alex wrote:And apparantly panel filters dont filter properly
- mc_hawkings24
So were the power figures down or up with the ebay chips?
i found these on ebay http://shop.ebay.co.uk/i.html?_nkw=bmw+ ... m270.l1313
i'am using thismc_hawkings24 wrote:So were the power figures down or up with the ebay chips?
http://cgi.ebay.co.uk/EURO-92-94-BMW-E3 ... 5ada62b09b
deffintly worth it
- mc_hawkings24
Thanks ive contacted him to see if he has any left. On another note as i have two ecu's i cracked them open and the eproms chip numbers are 1 267 356 288 and 1267355509
standard chips?
standard chips?
- mc_hawkings24
nope but i didnt zap them i only took the covers off to look
- mc_hawkings24
Had a mix up i had two 325i ecu's that i thought were 318is 16v ecu's as i just compared them to the one in my car.
The real 318is 16v ecu number i have is
261 200 175 thats on the case
and the eprom chip number from what i can make out reads 1267356346
and i just found this on google
BMW 318iS 18L E30 100KW 1734060 06521 M17 CHK:3F8B BOSCH 0261200175 1267356346
so looks like the numbers are right
just hope i this bloke can sort me out as it would be a cheap upgrade but then lifes never easy
Ant
- Retired Team Member
- Contact:
I dont know...
cheap is the byword on here of late, gambling on unknown chips, tsk tsk
Email FTW
- mc_hawkings24
well we still have the standard ones to fall back on ;)
I have had an Evolve chip and an A Tech chip in mine and had them both on the dyno. The Evolve tested at Frosts in Ipswich showed 136 bhp and the A Tech tested at Circuit Motors, Castle Coombe 143.6bhp. Then I had Paul at Circuit Motors remap the car to 147bhp.
I have access to an eprom writer at work... If the old chips are rewritable then I might be able to upload the remap onto it. will need a copy of the performance chip though, I'm not offering this as a service but I was thinking about getting a chip for mine anyway and might investigate further.
has anyone removed the sticker from their chip? if so was there a little window under it?
Yes, the BMW standard EPROMs are Eraseable (Programmable, Read Only Memories) so remove the label to expose the window then use an ultra-violet eraser for half an hour or so to blank it then it's reprogrammable again.
Ant
- Contact:
V not bad outa the boxI have had an Evolve chip and an A Tech chip in mine and had them both on the dyno. The Evolve tested at Frosts in Ipswich showed 136 bhp and the A Tech tested at Circuit Motors, Castle Coombe 143.6bhp. Then I had Paul at Circuit Motors remap the car to 147bhp
Email FTW
