HELP DISASTER ADVICE NEEDED!!!!
adit
Fri Jan 20, 2012 10:05 am
Tom_Maverick wrote:
...and penniless coonts who think they should get something for nothing..
unless the item belongs to them in which case it's worth well over the odds..
:chuckle:
sad, but true sometimes
[quote="bss325i"]
318isPMK
Fri Jan 20, 2012 10:33 am
I dont follow that Tom
Jimbob
Fri Jan 20, 2012 11:41 am
ECP are a mixed bag, I ordered some engine mounts from them that were listed as E25 M5 on their website, though the sticker on the box said E30/E34 - needless to say they weren't the right ones..I then ordered E24 mounts which came stickered up as E28!
rhubarb
Fri Jan 20, 2012 12:02 pm
Wouldn't use ECP or GSF for anything...Most of there stuff is cheap crap..And there customer service is crap too..Plus 9/10 the order is wrong..
Local motor factors for me everytime..
Tom_Maverick
Fri Jan 20, 2012 12:04 pm
There's a geezer in my local GSF that owns a sport.. helpful as anything and they do OEM quality parts.. just don't opt for the cheaper stuff!
Fri Jan 20, 2012 12:09 pm
Never had poor customer service from GSF, but I get it regular from ECP, especially when they fook up and owe me money :roll:
gary
Fri Jan 20, 2012 12:40 pm
Hi mate,
Been reading this thread through. Sorry to hear of your misfortune.
I may have missed it, through some of the guff on here, but what went wrong with the engine.
HairyScreech
Fri Jan 20, 2012 12:46 pm
currently open to speculation pending boyds damage assessment.
But, some kind of timing failure is likely, as the engine suddenly lost compression on all 4 cylinders at once, so pretty catastrophic.
ross_jsy
Fri Jan 20, 2012 12:56 pm
Considered dropping a m20b25 in the bay? Be a whole lot cheaper and 6 pot rightness to boot.
Andyboy
Alpina Colada
Fri Jan 20, 2012 1:00 pm
The chain is still there and intact. So, it's jumped teeth and bent valves, and the normal cause is that the small idler gear has failed -it's No.11 on this pic:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=25
It could be the tensioner blade or the guide rail (6 and 14) but that idler gear was well known to fail which is why BMW replaced it in late 1993 with a curved guide rail. Unfortunately, to convert to the later set up you'll need a lower front timing case as well. A new gear is £100.
318isPMK
Cheers Gary,
Dont know for sure i was driving then lost all compression (power) Mechanic and AA guy reckon from ear it was turning over too fast and had issues with the Chain.... When the rocker cover was taken off the Chain is intact so by process of elimination mechanic reckons it will be tensioners have failed and the chain has jumped its getting a good going over at the moment.
I am awaiting confirmation of all the above
318isPMK
Fri Jan 20, 2012 1:02 pm
I dont know about changing engines and all that its sounds dear and means I'm buying an engine I dont know so could end up back in the mud again.... plus I'm 26 so insurance premiums on a modified car with a replacement engine will end me!
I would imagine
Fri Jan 20, 2012 1:05 pm
I suppose that being a relatively early example of a 16-valve engine in a production car, there are bound to be the odd weak links, so to speak, although it's covered a decent mileage to be fair.
Has the cylinder head been removed for a look-see?
318isPMK
Fri Jan 20, 2012 1:10 pm
Boyd will say for sure but yes he mentioned head removal if thats the same thing
318isPMK
Fri Jan 20, 2012 1:11 pm
How do you get the wee pic on the left hand side of your post i have a pic I want to stick there
Fri Jan 20, 2012 1:22 pm
Go into your Profile, and add a link where it says Avatar Control panel, down the bottom.
kam-325i
Fri Jan 20, 2012 1:24 pm
Speedtouch wrote:I suppose that being a relatively early example of a 16-valve engine in a production car,
For BMW or just in general ?
Fri Jan 20, 2012 1:26 pm
Well, in general. They brought out some 16-valve engines in road cars back in the 1970s, e.g., Lotus and Jensen-Healey, Dolomite Sprints, Vauxhall Firenzas, etc., and they tended to have quite alot of issues, so for a 1980s valver to cover 140,000 miles isn't bad really.
318isPMK
Fri Jan 20, 2012 1:39 pm
what Avatar is better I cant decide :)
318isPMK
Fri Jan 20, 2012 1:40 pm
or that
318isPMK
Balls its not working oh well never mnd back to work!
Rtaylor2208
Fri Jan 20, 2012 2:17 pm
Try it out in the test forum, I took a good few attempts for me just to get the sig picture to work and still not that happy with it.
We've given you a whole forum to play around with this kind of thing, without messing up threads in the main forums: http://www.e30zone.net/modules.php?name ... forum&f=13
318isPMK
Fri Jan 20, 2012 2:45 pm
ooops Sorry Brian
ross_jsy
318isPMK wrote:I dont know about changing engines and all that its sounds dear and means I'm buying an engine I dont know so could end up back in the mud again.... plus I'm 26 so insurance premiums on a modified car with a replacement engine will end me!
I would imagine
Engine wouldn't be to pricey at all. Could pick up one off here for around the £300 ish mark. Yes it's a gamble on how it runs, but m20's are simple. £100 or so for timing belt (m20's are belt) and water pump so you know it won't fail and away you go.
You have the advantage of having 51mm struts and rear discs being an iS. Only thing I'm unsure of is wiring, but it will be easy.
Can't possibly comment on insurance though.
Just food for thought
HairyScreech
Fri Jan 20, 2012 2:52 pm
provided you get the whole engine loom with the engine and its a facelift job then its as simple as just popping the ecu plug through the bulk head and connecting the c101 plug.
dash then needs a 6 pot coding plug as does the obc.
Fri Jan 20, 2012 2:54 pm
I would imagine
He then needs a gearbox , clutch,mounts, prop , diff, radiator , hoses etc etc etc and to pay someone to fit it.
Only on the zone do engine conversions cost £200 :(
ross_jsy
Fri Jan 20, 2012 2:57 pm
Mmmm, would be possible to get it from a breaker but it is hassle if you don't have the knowledge/back passaged rammed full of parts
318isPMK
Fri Jan 20, 2012 3:00 pm
zactly!
318isPMK
Fri Jan 20, 2012 4:17 pm
Its under the nife as we speak
Andyboy
Alpina Colada
Fri Jan 20, 2012 5:00 pm
Knife?
Give me a screwdriver and a Scottish E30. I'd love 10 minutes with that up on a ramp! winkeye
318isPMK
Fri Jan 20, 2012 5:10 pm
Okay.... I dont get it :)
Aye knife im a little retarded
Jimbob
Fri Jan 20, 2012 5:27 pm
He's talking about rust :)
Fri Jan 20, 2012 5:34 pm
318isPMK wrote:Okay.... I dont get it :)
Scottish screwdriver test -
[youtube][/youtube]
:eek:
Grrrmachine
E30 Zone Wiki / Team Member
Fri Jan 20, 2012 5:42 pm
Did you just put up a video of a BEETLE on here? :evil:
We'll have to disinfect the entire site now
