gooner1
- Out humping Reindeer
Post
Thu Aug 23, 2012 4:59 pm
DanThe wrote:gooner1 wrote:£95.52 for 11 core plugs.
WTF! I bought a set for an M50 last year for under £15
You had better leave them in Rob!
Thing is Dan, I'm taking the block to be chemically cleaned to rebuild standards, same place that done my cylinder head, and he's insisting that to do it properly the plugs have to come out.
Beginning to wish i;d gone down the M52 route now.
Post
Thu Aug 23, 2012 7:09 pm
Have you tried a different supplier?
gooner1
Post
Fri Aug 24, 2012 6:00 am
DanThe wrote:Have you tried a different supplier?
No mate, apparently the plugs are a knats knacker under or over
45mm and BMW are the only supplier of that particular size.
Unless anyone knows different pf course.
Demlotcrew
Post
Fri Aug 24, 2012 11:17 am
I bought a new Carpet for the Cecotto, at time of order it was £460, when the carpet arrived (296 days later) it was £730!
Lucky for me my dealer honoured the ordered price.
maggspower
- Turbo Farmer Tractor Driver
Post
Fri Aug 24, 2012 11:38 am
gooner1 wrote:DanThe wrote:Have you tried a different supplier?
I have a block with the plugs out at the moment, I also have some OEM plugs that I bought a while ago (about £20 IIRC
) I'll measure them both for you. But in the meantime hear is something to think about;
http://www.ebay.co.uk/itm/310283687022? ... 26_rdc%3D1
If there is a problem starting them in the hole a file will help, then just whack away with a socket, the plug must be an interference fit and will deform to fit the hole. A smear of setting sealer can be used too, but they should seal anyway as long as the hole is in good condition and clean.
gooner1
Post
Fri Aug 24, 2012 11:46 am
Thanks for that Mags, don't want to sell your OEM plugs do you
Demlotcrew
Post
Fri Aug 24, 2012 11:50 am
Only use a socket thats just small enough to fit on the edge of the plug, if you use a small socket on the centre you run the risk of collapsing the plug and it wont seal.
Post
Fri Aug 24, 2012 12:41 pm
Searching on google they are all coming back at 45mm
gooner1
Post
Fri Aug 24, 2012 3:59 pm
DanThe wrote:gooner1 wrote:DanThe wrote:Have you tried a different supplier?
Exactly Dan, 45mm is either slightly too big or too small, can't
remember which tbh.
swindler
Post
Fri Aug 24, 2012 5:41 pm
Demlotcrew wrote:I bought a new Carpet for the Cecotto, at time of order it was £460, when the carpet arrived (296 days later) it was £730!
Was this recently? Did it come with the plastic heel pad?
Demlotcrew
Post
Fri Aug 24, 2012 5:49 pm
Yes only last month. Unfortunately there is no heel pad, foot rest pad or accelerator rubbing pad, lucky for me the Cecotto came as standard with the ///M footrest which will cover the pad anyway and the floor mats will hide the heel ones.
Im in two minds about keeping it, just seems like a total over sight from BMW Classic!
harry_p
Post
Fri Aug 24, 2012 6:18 pm
For that sort of money the omissions are just unacceptable
cheers,
harry
Post
Fri Aug 24, 2012 7:32 pm
Demlotcrew wrote:Yes only last month. Unfortunately there is no heel pad, foot rest pad or accelerator rubbing pad, lucky for me the Cecotto came as standard with the ///M footrest which will cover the pad anyway and the floor mats will hide the heel ones.
You've been bummed across the parts counter big style! No wonder your so menstrual at the moment
Your not likely to sell it on at that money either, id be chucking it back pronto.
Demlotcrew
Post
Fri Aug 24, 2012 9:23 pm
You win some you loose some
I wont loose any sleep.
maggspower
Post
Wed Aug 29, 2012 10:19 am
gooner1 wrote:Thanks for that Mags, don't want to sell your OEM plugs do you
Yo, sorry for the late reply on this, no sorry can't sell the plugs that I have as I would then be in the same position as you
However the good news is, the core plugs measure 45.35mm, if you check out the ebay ad I posted up it says the the plugs they have are 0.25-0.40mm over the stated size, so these I feel would be perfect for your application.
HTH
Topblag
Post
Mon Sep 03, 2012 1:10 pm
Just off the phone to the local dealer.....
Rear light seals - facelift - £15.05 each
Toolkit foam backing - £11.20 each
If anyone knows if I can get any of these elsewhere I'll be happy to hear from you but given they are quite specific and unlikely to be replaced often, I doubt they're available.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
- **BANNED**
Post
Mon Sep 03, 2012 3:03 pm
Topblag wrote:Just off the phone to the local dealer.....
At a guess,the guys in Munich are saying;
'Got in himmel,ve 've de parts remanufactured a' vu is moaning at de cost? Go an' buy ze Ford!'
Topblag
Post
Mon Sep 03, 2012 3:11 pm
light seals I can just about swallow (because of the cost to repair the damage caused by water in your boot), but £11.20 for a small section of foam is a bit much given that the bonnet sound insulation is about 20 times the size and only £40.
10 under dash panel plastic screws, 10 clips for holding the plastic rub strips onto a preface bumper, 2 preface and 2 facelift rear light seals and 2 toolkit foams, before discount - £83,10.
gman1
Post
Mon Sep 03, 2012 8:21 pm
rear boot badge...£27.00
Topblag
Post
Mon Sep 03, 2012 9:48 pm
gman1 wrote:rear boot badge...£27.00
that trumps £30 for two light seals.
Andyboy
- Alpina Colada
Post
Tue Apr 21, 2015 11:17 am
NEW SHOCKER!!
E32 or E34 instrument cluster SI board.
£1150. Plus VAT.
That's right -
thirteen hundred pounds.
I thought £60 for an E36 brake light switch was steep.
Jesus Christ!!
Post
Tue Apr 21, 2015 12:44 pm
I phoned BMW yesterday for a bulkhead wiring cover, spoke to a new guy who said "oh thats an old car mayyyt, I think you will struggle with parts for these now"
Cock..
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Post
Tue Apr 21, 2015 1:30 pm
DanThe wrote:I phoned BMW yesterday for a bulkhead wiring cover, spoke to a new guy who said "oh thats an old car mayyyt, I think you will struggle with parts for these now"
c**k..
i can hear Pete cracking one off....
ross_jsy
Post
Tue Apr 21, 2015 7:43 pm
c**k..
4 cylinder one?
When I bought mine I was told it was one of only 2 left in the UK at the time, wonder if they have ran out?
Post
Tue Apr 21, 2015 8:12 pm
Yes Ross
Sorry to spoil petes fun but he checked availability and there are 600 odd in Germany
ross_jsy
Post
Tue Apr 21, 2015 9:20 pm
Ah balls, thought it was time to stick it up for sale. "IT'S STRONG!! RARE!!!"
Post
Tue Apr 21, 2015 9:23 pm
Could be a new selling point though, "ITS NOT RARE BUT *****IT ROCKS***** GET THEM WHILE THEYRE AVAILABLE!!!!!"
ross_jsy
Post
Tue Apr 21, 2015 10:10 pm
"Less than 7 86 available worldwide!!!"
spook
- League two here we come !!!
Post
Tue Apr 21, 2015 10:43 pm
The bloke at the main dealer didn't laugh when I asked how much do I need to bend over for to buy ABS sensors after ordering a rev sensor @ £150 FFS.
