Post Sun Jan 12, 2014 12:33 am
LOL, you're closer now.
:wink:
Post Sun Jan 12, 2014 12:39 am
Rav335uk wrote:LOL, you're closer now.
:wink:
i know you miss me :D
gooseygander110
Post Sun Jan 12, 2014 12:40 am
test fitted 6 sd box ..... 8)
:wink:
Fook off! :D
Cypriotgeeza
Post Sun Jan 12, 2014 12:44 am
magpie wrote:Nothing,i fookin hate the winter :(
+1!
Check my M30 build threads:
Post Sun Jan 12, 2014 12:46 am
+1!
You is in the wrong country "Bro" :D
Cypriotgeeza
Post Sun Jan 12, 2014 12:59 am
Rav335uk wrote:
+1!
I know bro! Lol :(
janc
Post Sun Jan 12, 2014 8:39 am
Went to have a look at her. Lonely on garage. Re-connected battery started her up. First time. Bloody fantastic but then brake warning lights came on. Handbrake and brake. Unknown! brakes have been off all winter parked on trainers, probably needs a run. A few more weeks of hibernation as a cold spell forecast. Seen a a lot more salt wagons recently.
G-Bear
Post Sun Jan 12, 2014 9:25 am
timmzey wrote:
I wouldn't have thought it, but those roof rack bars look great. Where are they from? An E46?
scjimbo
Post Sun Jan 12, 2014 9:27 am
Took mine out for a run, cleaned it and put it back on its garage.
Flute
Post Sun Jan 12, 2014 6:56 pm
Checked out the electrics and then fired her up after a service. Still off road but ran very well on tickover. Cannot wait to start restoring her and I'm sure she is a keeper. I will post the photos as I go on this great journey.
Flute.
milescook
Post Thu Jan 16, 2014 1:36 pm
The other day, did this Mondeo ARB link upgrade:
I also have tie rod ends to go on (WD40 applied in anticipation) as well as new arm bushes... it's going up to maggspower for that sometime...
Today, adjusted my boot so it doesn't rattle as much (I hope). Cleared out the nearside boot well of about 10 cm of water :( Spotted a couple of pages ago here the problem could be my aerial, which I removed and taped over. Might investigate how good a job this tape is doing....
Oh, and even though technically It's up for sale and the previous owner wants to buy it back (with my work), booking myself for a track day in Llandow :o: I just can't let go....
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Post Thu Jan 16, 2014 2:12 pm
what year mondeo are the drop-links for and are they a straight swap over ?
milescook
Post Thu Jan 16, 2014 2:20 pm
Bottom of the page Mick
http://www.e30zone.net/e30zonewiki/inde ... Drop_Links
Yep, as you can see the bracket is no longer required. I just supplied my own couple of nuts and washers. Pretty straightforward swap.
Not sure how much improvement it is over standard fresh E30 links as mine were knackered. But it feels fine and dandy anyway.
Post Thu Jan 16, 2014 3:00 pm
good stuff Miles :thumb:
where did you get them ?
G-Bear
Post Thu Jan 16, 2014 4:37 pm
magpie wrote:good stuff Miles :thumb:
Part number here for lemforder..
http://www.e30zone.net/e30zonewiki/index.php/Bushes
Get them cheapest from Car Parts For Less. about £35-40 for the two if I remember correctly.
@ milescook performance wise they're not an upgrade. Just built better than the E30 design therefore hopefully shall last longer.
G-Bear
Post Thu Jan 16, 2014 4:44 pm
Because I like you Mick..
http://www.carparts4less.co.uk/cp4l/c/F ... 414&000016
milescook
Post Thu Jan 16, 2014 4:59 pm
Sounds good to me :)
G-Bear
Post Thu Jan 16, 2014 5:00 pm
They look pretty too :D
hammersfan12
Post Thu Jan 16, 2014 5:16 pm
put a new coolant temp sensor on, seems to be running better. although over the last week it's had a new inlet boot and leads put on which have helped. it purrs again lol :D
Post Thu Jan 16, 2014 6:22 pm
thanks lads ,ordered and sorted 8)
scott180gtb
Post Fri Jan 17, 2014 5:24 pm
Sold my sport today. :(
JBU has gone to a good home and I'm sure she will be looked after.
Time for something with some serious grunt. :D
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
bigwinn
Post Sat Jan 18, 2014 6:57 pm
Green Touring passed its MOT after some remedial works!
Another year without the Chinese making a toaster out of it
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Post Sat Jan 18, 2014 6:58 pm
Fitted some smoked headlights :cool:
oomz1975
Post Sat Jan 25, 2014 5:31 pm
Bought a 19mm swan neck spanner,
Replaced the blue temp sensor with new one,
Topped up coolant,
Stopped annoying squeal from alternator pulley with wd40,
Went shopping...
davidt
Pompey Council 4 door deviant
Post Sat Jan 25, 2014 8:19 pm
Fitted four new Ronal LS wheels and Falken tyres
LondonTom
Post Sun Jan 26, 2014 6:57 pm
Bought it some presents:
pac1982
Post Sun Jan 26, 2014 7:29 pm
Fitted some E34 foglights to my E30 winkeye
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
jimbom30cab
Tech 1 freak
Post Sun Jan 26, 2014 11:21 pm
Great wheels Dave, looking forward to seeing them
HenryM3
Post Fri Jan 31, 2014 8:47 pm
Finally, finally, finally found my battery drain, I think??
ross_jsy
Post Fri Jan 31, 2014 8:59 pm
Hooked some lights up in my garage and installed a radio so now I have no excuse for neglecting the turd. I really need to finish it, it's been 3+ years now!
Fitted DanThe's fan wiring loom and added a plug and socket to it and the fan side (look at the 3 years of much on the chassis!):
Had to use a 4 pin connector as it's all the auto electricians had and I wasn't going to buy a full plug kit. The joys of living on an island :roll:
Also fitted a replacement indicator stalk as I broke the original test fitting the rear half of the cage. Bought the stalk (off Trev I think) about 2 years ago. Really need to get my act together with this turd!
milescook
Post Fri Jan 31, 2014 9:02 pm
Brimmed the tank, fixed my offside indicator (turns out a wire in the cab has been disconnected for at least a year), loaded it with tools and tyres and heading off to Llandow tomorrow.... :eek:
Funnybear
Post Sat Feb 01, 2014 12:53 pm
RSlut wrote:Bought it some presents:
Any chance your car is black too? Any chance of some piccies. Looking for something to replace my knackered old alpina rep 17's. (I know, I know. School of chav. They where there already.)
Flute
Post Sat Feb 01, 2014 9:20 pm
Bought my neon blue car in November, think we've had two good days at the weekends on work on her. Last week was one of those days, worked on the roof replacing a seriously bent roof lift/lower bar and swivel.
Roll on spring ;)
Flute.
LondonTom
Post Sun Feb 02, 2014 8:51 am
Not black - mine's is grey.
These aren't getting fitted until next week.
Tom
