190mph? Possible?
Kos
Fri Jan 29, 2010 1:05 am
he was a touch expensive but his stuff was usually decent.
how did you get on with your rear diff hanger ? i've just done it to my M3
www.pukardesigns.com
IG Pukar.Designs
g57yle
Boost Junkie
Fri Jan 29, 2010 8:54 am
i cut the entire boot floor out and made my own structure, used an m5 diff and e46m3 diff cover.
Fri Jan 29, 2010 9:24 am
Was it your car that ripped the diff out? Remember some pics of twisted/torn metal :)
g57yle
Boost Junkie
Fri Jan 29, 2010 4:53 pm
DanThe wrote:Was it your car that ripped the diff out? Remember some pics of twisted/torn metal :)
Yes indeed, that was definately my car. ripped out at acceleration from 130 onwards.
elnino1980
Fri Jan 29, 2010 6:33 pm
bmw e30 325i
bhp 212
top speed 138 @ 5200rpm
g57yle
Boost Junkie
Fri Jan 29, 2010 6:47 pm
elnino1980 wrote:bmw e30 325i
bhp 212
oh kay?? LOL
Mine :
BHP 629.3
Top speed geared to 238mph but i backed off at 187 gps speed
DHFiS
Fri Jan 29, 2010 8:04 pm
bhp 212
oh kay?? LOL
Mine :
BHP 629.3
So you have a little less power than an F1 car, a higher top speed and non of the aero?
g57yle
Boost Junkie
Fri Jan 29, 2010 8:09 pm
Something like that :)
Only some M3 aerodynamics, will be re-installing the flat panels under the car, and some sort of front air dam and splitter, not forgetting the rear diffuser
DHFiS
Fri Jan 29, 2010 8:15 pm
There is a good view of the underside of the car in this clip.
g57yle
Boost Junkie
Fri Jan 29, 2010 8:17 pm
DHFiS wrote:There is a good view of the underside of the car in this clip.
Yes, i saw this years ago, there is also a vid of an RX7 doing 215mph and does the same thing. this is the main reason i didnt exceed 200mph.
Fri Jan 29, 2010 8:45 pm
[youtube][/youtube]
g57yle
Boost Junkie
Fri Jan 29, 2010 10:29 pm
DanThe wrote:[youtube][/youtube]
Thats what i was talking about. I though it was 215. Maybe ill go for 200 then
DHFiS
Sat Jan 30, 2010 12:10 am
make sure you get it on film :D
HairyScreech
Sat Jan 30, 2010 2:35 am
DHFiS wrote:
bhp 212
oh kay?? LOL
Mine :
BHP 629.3
yes, but your missing a major factor. the f1 car will have significantly more drag at those kind of speeds for 3 reasons.
1: its an open cockpit vehicle, which causes masses of drag
2: its an open wheel vehicle, which causes masses of drag
3: its set up for high downforce with in excess of 600kg of downforce at those speeds, which causes masses of drag.
basically by having "non of the aero" hes far better off. all those wings and bits are there to get it around a corner faster, not make it faster in a straight line. if you enclosed the wheels of the f1 car, put an aircraft style canopy on it and removed all the wings, (basically going "bullet") you would be looking at a much faster f1 car in a straight line but one that would be shit (and illegal) in an f1 race.
theres something else your forgetting, his car is turbocharged and an f1 car is na.
now i cba to go into the why, but he will have a hell of a lot more torque than the f1 car, which makes a big difference, after all its the area under the graph which dictates a fast car.
Messenjah
Sat Jan 30, 2010 9:23 am
well it looks like its already been prooved that it is possible i was just going to chuck in that if terry davies has had his mk2 escort with a 2.0 yb engine up to 180 with a missfire in 5th and no nitrous im pretty sure you can make an e30 crack 190
madaboutthe30
Sat Jan 30, 2010 11:26 am
Correct me if Im wrong but the reason the rx7 lost it is because after 200 mark the owner increase the oxygen mixture which created an imbalance and he then lost it no the speed itself at the time
Dreaming of the day I purchase an E30 M3
--- e30 motorsport cab-- in the process of becoming a trailer queen
--- Z4M Coupe - daily driver
snakebrain
Sat Jan 30, 2010 12:45 pm
Dan318-is wrote:it wouldn't suprise me if enough lift was created to lift the thing of the ground!
Yeah, that's what I was thinking. Wouldn't worry so much about bits flying off as the whole thing taking off! :D
snakebrain
Sat Jan 30, 2010 12:52 pm
g57yle wrote:I can say i have achieved 190mph in an E30 (off public roads) and still pulling hard @629hp but backed off as i could feel too much lift
The car started feeling light at approx 150+.
Just read the rest of the thread....190 in an e30?! I'm amazed but impressed that it stayed on the ground. I wonder how long it would have if you'd maintained 190? lol
You're nuts, btw!! In the nicest possible way! :D :D
g57yle
Boost Junkie
Sat Jan 30, 2010 1:11 pm
madaboutthe30 wrote:Correct me if Im wrong but the reason the rx7 lost it is because after 200 mark the owner increase the oxygen mixture which created an imbalance and he then lost it no the speed itself at the time
Correct, but im pritty sure that if it had enough downforce theres no way he would have lost it at over 200.
Im not bothered if i can do 200mph just as long as i know its planted!
g57yle
Boost Junkie
Sat Jan 30, 2010 1:13 pm
LOL, Thanks. I did catch some wind decelerating around 175 and wasnt funny AT ALL!
DHFiS
Sat Jan 30, 2010 4:56 pm
Its possible the increased oxygen boosted the engine to the point the tyres could no longer transmit the power to the track surface.
murran
Sat Jan 30, 2010 7:19 pm
plus its on salt flats........ slippery!
he was lucky to get out in one piece i think. could have started rolling end to end.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
