Red oxide primer
Finto_316
Thu Jun 13, 2013 1:32 am
Hi,
i am going to be attempting a home respray and underseal in the coming weeks, i shall be making a diy spray booth outside with heavy duty plastic and a wooden frame. As it is outside im just wondering can you prime a car in red oxide to protect it before body prep?
thanks
BMW e30 325i Sport-88-Diamond Shwartz
Gavla
Thu Jun 13, 2013 8:40 pm
I have been looking into various different products over the last few months and the one I like the most is the Eastwood Rubberized Rust Encapsulator.
http://www.frost.co.uk/rubberized-rust- ... quart.html
For your purposes you would thin by 20% and probably do two thin coats. I will be stripping my floor and underside and be using this once it is all cleaned up.
Let us know what you decide and how you get on.
Jesus325iTouring
Frog freak !
Frog freak !
Thu Jun 13, 2013 10:44 pm
I've found in the past that red oxide tends to react with cellulose, this is just a personal experience, i'm by no means any kind of paint expert.
Finto_316
Fri Jun 14, 2013 2:37 am
hi ,
i sanded down a wing which has been filled and resprayed before, because the red oxide was thick stuff it filles most of the imperfections , 3 small dents to fill, but ill post pics tommorow!
Also its a good rust preventative! i think im going with waterbased as cellulose gives off poisonous gases 8O
