Morat
Tue Dec 18, 2012 9:23 am
I waved mine away as it was taken to the Autohaus to have a full service and diagnosis on the misfire and hard hot restart problems. I checked the wiki, I searched the threads and once I'd failed to rule out Blue Temp Sensor, ICV, TPS, Air leak, C101, leaky injector, failed non-return valve on the fuel pump I gave up and called an expert :)
Let's see how it does!
What has everyone else been up to?
FinalD
Tue Dec 18, 2012 9:30 am
At the weekend I rebushed the rear of mine, yesterday I tried (and failed) to get the diff back on due to the prop shaft having extended. Tonight I plan on sorting the prop and the diff, then if time allows, get started on fitting the new brake components to the rear.
Motorhole
Tue Dec 18, 2012 9:52 am
Wrapped up for Christmas now. But on Sunday I fitted my pedal box and made a blanking plate for the now redundant bulkhead apertures in the driver's footwell.
beemerbird
Tue Dec 18, 2012 10:32 am
I took mine to my local BMW parts department to buy valves for it's wash wipe system, as my temporary fix is more temporary than planned :(
staley_turbo
Tue Dec 18, 2012 10:48 am
I watched mine rust away just a little more.
Grrrmachine
E30 Zone Wiki / Team Member
Tue Dec 18, 2012 11:03 am
Mine's off to a mechanic for the rear wheel bearings tomorrow, and I hope my new washer jets turn up this week as it's got a 1000km round trip to do at the weekend, in minus 26 degrees :D
age
Formerly twist316
Tue Dec 18, 2012 11:10 am
jesus is it that bad up there, not looking forward to friday so :(
verde
Tue Dec 18, 2012 11:19 am
Brought mine indoors, ripped it to bits, test fitted its tech 2 kit and began masking up the windows for paint
Raise hell praise Dale.
G-Bear
Tue Dec 18, 2012 11:20 am
My most recent fix was replacing the broken reverse light switch on gear box housing. It was like that when I bought it in the summer. I love the small fixes like this. Such a treat to reverse in the dark now.. :D
Tue Dec 18, 2012 11:31 am
verde wrote:Brought mine indoors, ripped it to bits, test fitted its tech 2 kit and began masking up the windows for paint
Remove all the glass instead of masking for nice job.
E30 glass, especially on a 2dr is easy to remove.
Tue Dec 18, 2012 11:35 am
i'm making e30 christmas prezzies because i can't work outside today .
here's a clue .....
winkeye
FinalD
Tue Dec 18, 2012 12:09 pm
bss325i wrote:Remove all the glass instead of masking for nice job.
A nice lumphammer works wonders.... :P
verde
Tue Dec 18, 2012 12:15 pm
Alright thanks Barry, will look a lot tidier, it has pop outs too so they come out very easily. Very excited to see the finished product
Rtaylor2208
Tue Dec 18, 2012 12:20 pm
Absolutly fook all done with mine since the 1st of September. Building up what seems like a stock pile of new shiny bits to replace on the cab but no time or the inclination to work on it when its cold.
maf260
Tue Dec 18, 2012 12:23 pm
Rtaylor2208 wrote:Absolutly fook all done with mine since the 1st of September. Building up what seems like a stock pile of new shiny bits to replace on the cab but no time or the inclination to work on it when its cold.
^^^^This, although most of my lack of inclination is due to getting a new car this weekend and therefore having something else to give my attention.
mcbonio
Tue Dec 18, 2012 12:26 pm
Replaced the engine mounts in my m30'd e30. So smooth, no longer feels like the engine is on the seat next to you.! ahhhh
Rtaylor2208
For me its a baby on the way in february and the house resembling a building site while I desperatly try to finish the kitchen and nursey. The E30 wont see much love from me for a while.
Topblag
Tue Dec 18, 2012 12:46 pm
I put my IX back together at the weekend after removing the carpet due to a leak into each footwell. Leaks now sorted and car back together, carpet currently drip drying in the garage and car will run over the winter with no carpet to ensure leaks are fixed before carpet goes back in.
Next up is bring back an IX transfer case from Houston and fit it, which will be a challenge !
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
**BANNED**
Tue Dec 18, 2012 1:22 pm
Rtaylor2208 wrote:For me its a baby on the way in february and the house resembling a building site while I desperately try to finish the kitchen and the E30's new home. The E30 wont see much love from me for a while.
EFA! :D
Cloggy Saint
Tue Dec 18, 2012 3:01 pm
Today I have mostly been replacing timing belt/tensioner and water pump, next up is a new clutch.
G-Bear
Tue Dec 18, 2012 3:33 pm
Cloggy Saint wrote:Today I have mostly been replacing timing belt/tensioner and water pump.
I got this up next. Saving it for the new year along with the tappets. Then it's a bush overhaul and replacing a leaky steering rack with an E46 clubsport one.
verde
Tue Dec 18, 2012 3:35 pm
Cloggy Saint wrote:Today I have mostly been replacing timing belt/tensioner and water pump, next up is a new clutch.
Thanks for reminding me, just off to order a new water pump
The_Diddler
Love it up the more door !
Tue Dec 18, 2012 3:37 pm
Look at it in the garage and think to myself i must get around to finish building this turd, well not until its warms up a bit first.....
jimbom30cab
Tech 1 freak
Tue Dec 18, 2012 3:47 pm
yesterday i started preping the engine bay for re-spray
baggimodo
Tue Dec 18, 2012 4:10 pm
Spent most of my time researching what bits I'll need to replace the M40 with a M42.
To say I'm excited about the prospect of twice as many valves and cams would be an understatement. Revised my xmas list to include an engine stand :mad:
jimbom30cab
Tech 1 freak
Tue Dec 18, 2012 4:13 pm
great swap, you should chat with TPS who has just finished exactly this.
FinalD
Tue Dec 18, 2012 4:37 pm
baggimodo wrote:Revised my xmas list to include an engine stand :mad:
Really? I've never seen much point in a stand myself, unless you're stripping the block down and rebuilding it. Engine crane + pallet to store the engine(s) is all I've ever needed. :)
baggimodo
Tue Dec 18, 2012 4:48 pm
I do plan to get it stripped and look over it all before I chuck it in so I thought the engine stand would be ideal as I've got a very small workshop to work in and I'd be tripping over the lump if I left it on a pallet!
FinalD
Tue Dec 18, 2012 4:50 pm
Fair play then. They are handy, I've just never bothered to use one. It's sat at the side of the garage looking unloved, unlike the engine crane which is stood in the way and looking abused. :D
Z3I
Tue Dec 18, 2012 4:52 pm
Swapped over my SQR88 radio head unit for a nice working example just delivered from Ebay!
I'm happy now...
Grrrmachine
Tue Dec 18, 2012 7:29 pm
age wrote:jesus is it that bad up there, not looking forward to friday so :(
Surprisingly, it's warmer near where you're going. But I'm heading to the very north of Poland, where they've had two feet of snow already :D
You'll have a cracking trip across the mountains!
no1_jazz
Tue Dec 18, 2012 8:53 pm
Attempted to put a new fuel pump in the hope that it will fire up and start but No :mad:
Tue Dec 18, 2012 9:09 pm
Opened the garage door - remembered that the MOT is nearly up - closed garage door :(
kieran325
Tue Dec 18, 2012 9:11 pm
Nothing.
