WONT GO INTO GEAR .. HELP
buffalino
Thu Jun 10, 2010 12:45 am
HI ,,WHEN MY CAR IS COLD IT GOES INTO GEAR PERFECTLY,, BUT WHEN THE ENGINE IS HOT,, ITS HARD WORK TO MAKE IT GO INTO GEAR,, NORMALLY I HAVE TO SELECT 2ND AND THEN FIRST AT THE TRAFFIC LIGHTS,, WHAT DO YOU THINK CAN BE CAUSING THIS PROBLEM,,, ITS NORMALY THE OTHER WAY AROUND,,, HELP
wullie325i
CAUTION - unreliable trader!
Thu Jun 10, 2010 12:46 am
fluid issue or maybe the slave cylinder on the gearbox?
buffalino
Thu Jun 10, 2010 12:48 am
BUT ONLY WHEN ITS HOT,,, IS THAT CORRECT
wullie325i
Thu Jun 10, 2010 12:55 am
im not sure mate my first call would be drain the gearbox oil and clutch fluid top up bleed it back up and see where you are.
the slave cylinders go quite regular and start to cause selector problems or completely fail.
other than that its maybe a worn clutch/release bearing or pressure plate issue but i would try my first suggestion as its the easiest
buffalino
Thu Jun 10, 2010 12:58 am
ok thanks,, i see what happens
:cry:
wullie325i
Thu Jun 10, 2010 1:00 am
might not be any oil in the gearbox so its always a good idea to give it some tlc can really bring a box back to life again as so many people over look diff and gearbox fluid.
wullie325i
Thu Jun 10, 2010 1:01 am
when you try to select a gear and it wont go in does it make any difference if you lift of the clutch then put it back down again?
harry_p
Thu Jun 10, 2010 8:44 am
With it hot raise the car and watch the clutch hose while someone presses the pedal. The hose could be soft and ballooning when hot under pressure. Likewise, bleed the clutch cylinder, and air in there will expand when hot and make things worse.
cheers,
harry
buffalino
Fri Jun 11, 2010 4:29 pm
how do i check the gearbox fluid,,,
**BANNED**
Fri Jun 11, 2010 6:15 pm
With the car safely supported so that you can slide under it,on the o/s of the gearbox is a filler/level plug.Remove this and shove some oil in until it runs out.....
Youth is wasted on the young.
TheHeap
Fri Jun 11, 2010 6:37 pm
My Punto :o: does this only in 1st but i have sussed that when it refuses to go into gear i just softly lift the clutch pedal about an inch and pops right in.
e30-ryaner
Fri Jun 11, 2010 7:50 pm
sounds like your slave cylinders shot mate
buffalino
Sat Jun 12, 2010 10:46 am
CAN ANYBODY SEND ME A PIC OF WHERE THE SLAVE IS ,,THANKS ALSO NEED TO GET SOME SHOCKS I GOT KONIE FRONT A BACK,, LOWERED AND I NEED SOME NEW REAR SHOCKS,, WHAT DO YOU THINK OF BILSTEIN,, ARE THEY SOFTER
TheHeap
Sat Jun 12, 2010 12:45 pm
If it's the same as my e36 it's on the left side of the box if you stand under the car looking towards the front
