Aerial
braxtonator
BMW sell em at about 150ish
- **BANNED**
I bought a power aerial from my local car bits shop for around £30.
If you pull the boot side trim back you will see the gubbins,should be able to re-use the existing wiring.
Youth is wasted on the young.
- Brianmoooore
Isn't just the mast replaceable on the genuine BMW item?
- Contact:
BMW supply Hirschman aerials, I bought a black mast one about 3 years ago and it was £80 odd
The masts are replaceable and cost around £30 from BMW
That was the best reception id ever had in a car, its better than the poxy DAB I use now
- Cypriotgeeza
braxtonator wrote:BMW sell em at about 150ish
why dont you just buy a universal electric aerial?
Check my M30 build threads:
- Contact:
So boycott BMW
This is the exact aerial they sell but without the BMW box
http://cgi.ebay.co.uk/HIRSCHMANN-AUTA-2 ... 056wt_1167
- mc_hawkings24
I dont like em they always funk up at some point or get bent.
i'm looking at buying an m3 roof Ariel
Edit: found one http://cgi.ebay.co.uk/BMW-E30-M3-TOURIN ... 5ad3911c70
found cheaper anywhere else and powered?
- Brianmoooore
?? Nothing 'powered' about a touring aerial. The mast is removable (like a bayonet light bulb), but that's about it.mc_hawkings24 wrote:.... and powered?
- mc_hawkings24
as in power amplified, im still in my school days and like my pirate radio stations you seeBrianmoooore wrote:?? Nothing 'powered' about a touring aerial. The mast is removable (like a bayonet light bulb), but that's about it.mc_hawkings24 wrote:.... and powered?
braxtonator
Im buying one now as i got a halfords jobby which leaksDanThe wrote:So boycott BMW
Ollie_bwoii
I have the hirschmann aerial, it was a real bargain, the only thing that is strange is that when it goes up or down it makes a loud fuzzing sound, like when you are tuning for a radio station.
braxtonator
Yours must have rust inside it
Ollie_bwoii
Why? It was brand new a month or two ago. And was the first ever aerial the car has ever had fitted.braxtonator wrote:Yours must have rust inside it
- Contact:
I think you need a 'bee-sting'mc_hawkings24 wrote:as in power amplified, im still in my school days and like my pirate radio stations you seeBrianmoooore wrote:?? Nothing 'powered' about a touring aerial. The mast is removable (like a bayonet light bulb), but that's about it.mc_hawkings24 wrote:.... and powered?
- mc_hawkings24
are those roof aerials any good reception wise?
I've had beestings before and well dont think it would look right at the front lol
braxtonator
Because of all my E30's ive never had the noise u describe.Ollie_bwoii wrote:Why? It was brand new a month or two ago. And was the first ever aerial the car has ever had fitted.braxtonator wrote:Yours must have rust inside it
Ive had a humb that the motor makes when it is engaging
The aerial in my Saab diesel turd does this as well as in my e30 I suspect its interference caused my the motor in the aerial.Ollie_bwoii wrote:I have the hirschmann aerial, it was a real bargain, the only thing that is strange is that when it goes up or down it makes a loud fuzzing sound, like when you are tuning for a radio station.
- Brianmoooore
Can't say I've noticed any difference in reception quality between my E30 saloons and tourings, and signal levels around here are not brilliant! My E34 is noticeably poorer though. That uses the rear window element as the actual element, and I suspect a problem with the amplifier/filter tucked away behind the trim at the side.DanThe wrote:No, compared to a Hirschmann mast they are crap
- Contact:
E34 touring glass aerial is utter shite, this is why I used a DAB set, spent £50 on a roof mounted DAB aerial and its not as good as the old Hirschmann mast with a DAB splitter.
I used an E34 amplifier on my chromie as I didnt want to drill the quarter for a mast, used a loop of wire under the rear shelf. Its as crap as the E34 one
Ive got an E36 amp to fit when I get round to it
ive got one of these, very goodDanThe wrote:So boycott BMW
braxtonator
Straight fit?Alex wrote:ive got one of these, very goodDanThe wrote:So boycott BMW
I currently have a Tesco baggy jammed in the whole
braxtonator
I swear theres only 2 wires back there.Alex wrote:yep 3 wires and the aerial lead
What colour are the wires
Ollie_bwoii
I had 2 wires, a red an d a white one, then the aerial cable, and the short black earth cable!
