Please help
Confused but then it don't take much!!!!
essexgirlracer
- Essex meets organiser
- Contact:
Right I'm confused.......I can open my windows without my keys in the ignition if my drivers door is open which when you first get in your car and it's baking hot it's a really good thing ..........BUT I just got in Billy (the sport) to go lunch and done what I alway's do and it's not working????? Do any of you know what it could be!! I'm totally confused.........worked this morning but not working a few hours later????
Please help
Please help
- **BANNED**
Fuse?
Youth is wasted on the young.
essexgirlracer
- Contact:
nope it's fine hun it's the first thing I checked lol..........thats why I'm confused x x
Do the interior lights still come on when you open the driver's door? If not, I reckon the pin switch in the driver's doorjamb is stuck in, or the spring's popped out of it or something. Should be a simple fix.
"doughnuts - power braking in circles" Peterborough Evening Telegraph
essexgirlracer
- Contact:
Yeah all the interior lights still work babe x x
Probably something simple to be honest but tried all the obvious things x x
Morat
There are two fuses (sorry, can't remember which ones they are off the top of my head). Have you checked both? One is for when the ignition is on, one for when the doors are open/ign off.
essexgirlracer
- Contact:
didn't know there were 2 fuses so I will check cheers for that...... and I will try that hun too........cheers x x x x
beemerbird
My 2 door SE has the two modes. Can't remember which fuse numbers it is, tho!
essexgirlracer
- Contact:
The windows do work with the ignition on and with the car running...............cant remember about the switch light illumination though lol...........I will double check when I go home..........
Cheers for all your help guy's much appreciated x x
Morat
If the windows work with the door open/ignition off it won't be door pin related, or anything in common between the two systems (isolator switch, motors, etc). My money is on the fuse. I'm sure Brian has answered this sort of problem before and listed the fuses.
Morat
oh yeah, could be something else but definitely worth checking 17 before anything else (IMO).
Had this problem on my old 320i - it was the wiring loom that runs into the door from the A-post. A quick wiggle of the wires and it was working again.
- BadMoonRising
Mine did this. Gave it a whack and worked again
- chrisE318is
mine did exactly the same and was the fuse
breaking 2 door dolphin grey tec 2
pm me
pm me
essexgirlracer
- Contact:
I will check fuses again but seemed ok. Found that my cigarette lighter is not working either!!!! Went to use my itrip and there is no power, don't know of it was working before though as never used it before.
Poor Billy he needs some more TLC x x
