where are the fookin spark plugs
hi all, im askin this q for my bruv, he has a 325i cabs with the m50 engine conversion, he went and brought some sparkplugs the other day when we popped the bonnet we cant see where they are can any1 help, thanks, ps sorry if this sounds like a daft q.
above the exhaust manifold, just follow the ht leads
EDIT: just relised its an m50, then i think there like the m42 under the cover on the top of the engine
i relised before you postedSPADGE wrote:WrongAlex wrote:
above the exhaust manifold, just follow the ht leads![]()
yet again i didnt read it properly and just read where are the spark blugs on a 325i cab
The spark plugs are located underneath each individual coil pack, see where the wires are going to on this pic? Do one at a time and make sure you put the earth brackets back in the same place
Oh and there is no distributor
each of those square things are a coil, usually 2 10mm nuts holding them on, they then pop up a bit and you pull them upwards to reveal the spark plug, disconnect the lead to them by lifting the silver clamp on each one where the wires go in
This is what it looks like with coils & wirimg loom removed
pac1982
tmac2610 wrote:my bruv used to be a mechanic
I have never been a mechanic and have never worked on one of these engine before but even i would be able to find the plugs!!
prehaps thats why he used to be a mechanic
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
It would help if you just tried typing in plain old boring English. A novel idea verging on the radical I know but hey, give it a go!tmac2610 wrote:? is that the quote selected bit underneath the quick reply box
i think i knw wot i did,
Have you managed to change the plugs now?
he used to work for a place called kingfisher customs that only workt on vw's, i dnt know if vw made any engines like that. thats like saying he should av known there was no distributor, like spadge said the answer is easy if u knw it, mash i didnt see u write any thin until evry 1 else explaind and sent pics
i dnt take offence i just dont understand y u have to make a comment about a question, thats y were on here to ask wot were not sure about, we all may aswell go to grages if and not ask any questions if we just gonna get slagged.
Bob_S
Go back to school, learn how to read and write in the Queen's english and then try posting. I'm sure you will appreciate the difference. I know everybody else on here will!tmac2610 wrote:right how the fook do i stop this tex bolx from happenin its psn me of now.
Bollocks to this 24v scrap!
Dude, calm down.tmac2610 wrote:right how the fook do i stop this tex bolx from happenin its psn me of now.
When you don't type out full words you are getting into text speak and this forum has a filter set up that blocks people writing bollocks. It is rather irritating when people write in txt on a forum.
For the others, yes it is annoying when people use text speak, but calm down. Same goes for the criticisms of his question. We all have to learn somewhere.
Every day is a school day as they say
Bob_S
After asking where the plugs are on an M50.. I really think you should pipe downtmac2610 wrote:i doubt it coming from southend id be suprised if you could tell the time.
come on people its only abit of banter, i did apologies if it was a daft question in the first place so no need to keep goin on and on and on and on and on and on and on and on and on and on and on and on and on, can any one tell me what the vanos actually does?
