Thinking of a possible alternative to the usual BBS etc and am thinking about some 15" steelies.
What other cars do you know of will have the correct 4x100 PCD but also near enough the right size centre bore? Also very important, the wheels would need to be 7" wide or wider, which is where I believe a lot of the issues will be as the french scrap will only have 6J wheels
Any ideas folks?
What 15" steelies are good for an E30
Are vauxhall 4x100 or 4x108?
Is it Ford that is 4x108?
4 stud vauxhall are 4x100
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
What about g60 steelies, pretty sure there 7j, an £150 brand new for a set
I was going to buy a set an get them banded (www.wide-wheels.co.uk )
gareth
lagunas sometumes had 16" steelies in 4x100
otherwise it's 15" vauxhall or vw
do a search, it's been discussed a few times recently
Holden gemini (and therefore, i think the, old vaux chevette) have a 100x4 stud pattern and also a low offset. A lot of the 4x 100 stud pattern wheels have a big offset of 40ish ET. You want something closer to 25(or less).
gareth
that's where banding will come in useful, adding width to the outer rim on a vw wheel will get the width up nicely and set the ET where you want it
- engine_ear
BMW MINI
Been meaning to get hold of one to try out. No idea what the width or offset is tho...
Do know the centre-bore is a mm smaller than E30 so will need machining out.
1990 318i Touring
The red shed...
The red shed...
