Engine Swap - M6x
Revision as of 19:38, 10 April 2013 by Grrrmachine (talk | contribs)
Parts List
Engine
Left side engine mount
Therefore the engine options are:
Right side engine mount
Whether M60 or M62, all engines use an alloy block and head. After 1998, the M62 engines were fitted with VANOS. Despite the M62 being the more modern engine, we still favour the older, simpler M60 lump. For starters it's a sturdier construction which doesn't suffer from the broken chains that the M62 is becoming renowned for, and it also has a much simpler [M6x#Wiring|wiring]] setup.
Mounts
Oil Filter
Remote oil filter
Propshaft
Custom prop for 6-speed box
Gear Selector
Fan
Temp Switch
Exhaust
Manifold
Exhaust Pipes
EWS
Main article: EWS
Temp Sensor
