Engine Swap - M6x
Parts List
  • Full M6x Engine with all ancillaries (injectors, MAF, inlet, coil packs, alternator)
  • Engine mounts
  • Complete engine loom
  • Gearbox
  • Clutch
  • Propshaft
  • Differential
  • Exhaust including manifolds
  • Fan
  • Radiator
  • Universal Joint
  • Gear bridge
  • Brake servo
Engine
Left side engine mount
Right side engine mount
Mounts
Oil Filter
Remote oil filter
The 6-speed from the 540i offers a final gear, which provides a faster top speed if mated to the correct differential. However, it requires a custom propshaft to mate up to the differential; no standard solution is available.
You'll need the best possible clutch if you're going to make use of all that lovely lovely torque. Unfortunately, if you've opted to use a 5-speed gearbox then you can't use an off-the-shelf BMW clutch - you will have to contact a specialist clutch supplier. Helix can supply one if you ask nicely.
M60B40 and M62B44 friction plates have "larger diameter clutch shaft hole" than M60B30 / M62B35 friction plates (6speed vs 5speed 'box). Don't mix them up.
Propshaft
If you've chosen to use the 6-speed gearbox then you're committing yourself to a custom propshaft.
This needs to be chosen to match your gearbox due to the ratios you have available.
Fan
Temp Switch
Exhaust
Manifold
Exhaust Pipes
EWS
Main article: EWS
Temp Sensor
