Engine Swap - M6x
Parts List
- Engine mounts
- Complete engine loom
- Gearbox
- Clutch
- Propshaft
- Differential
- Exhaust including manifolds
- Fan
- Radiator
- Universal Joint
- Gear bridge
- Brake servo
Engine
Mounts
The 6-speed from the 540i offers a final gear, which provides a faster top speed if mated to the correct differential. However, it requires a custom propshaft to mate up to the differential; no standard solution is available.
You'll need the best possible clutch if you're going to make use of all that lovely lovely torque. Unfortunately, if you've opted to use a 5-speed gearbox then you can't use an off-the-shelf BMW clutch - you will have to contact a specialist clutch supplier. Helix can supply one if you ask nicely.
Propshaft
If you've chosen to use the 6-speed gearbox then you're committing yourself to a custom propshaft.
This needs to be chosen to match your gearbox.
Exhaust
Manifold
One of the most significant differences between the M60 and M62 engines is the wiring. The earlier engines used the traditional BMW route; an engine loom with integrated plug for the [M6x#ECU|ECU]], which then connects to the rest of the car using a standard BMW socket. In contrast, the later engines used BMW's Canbus system, which communicates with the rest of the car in an entirely different way. With Canbus, the ECU not only controls the engine, but also expects incoming signals from the gearbox, differential and braking systems in order to operate.
EWS
Main article: EWS
Temp Sensor
