Engine Swap - M20
There's no simpler swap from the possible choice of engines than the mighty M20. While the smallest version was 2.0 litres, its full-fat form is a 2.5 litre version, which is the only one worth having. Around town it gives all the smoothness you'd expect from a straight six, and there's plenty of grunt so you won't be chasing up and down the gears trying to find the right cruising speed. But let her rip, and she'll provide as much tail-happy sliding as you want.
The M20 swap is considered the easiest swap because all the parts are standard BMW. There's no need for custom parts, and everything you need can be supplied by one donor vehicle. The only part that may need some mild changing is the loom, and even that is specific to the age of your E30. We'll explain that later.
The M20 can be fitted to any E30, no matter whether it started life as an M10, M40 or M42. With the right base vehicle a weekend is enough to get everything bolted in and ready to go. You can even use this guide replace your existing M20 with a bigger version, and in that case the engines can be swapped over in a matter of hours.
The simplest M20-M20 swap will involve simply swapping the engine and gearbox. If coming from a four-pot base, you'll also need some cooling hoses. For a more thorough swap we also recommend replacing the Differential
Engine
Parts List
Your parts list.
While parts suppliers do list differences between B20 and B25 engines, there's no practical difference. A B20 clutch will work fine on a B25 engine.
Prop
Exhaust
