Engine Swap - M42
Revision as of 20:08, 10 February 2013 by Grrrmachine (talk | contribs)
The four-cylinder engines get a lot of stick from E30 owners. "Feeble", "weak" and "two pistons short" are the usual complaints made against the rattly M10 and its M40 sibling. And while it's true that the four-pots can feel a bit asthmatic after driving a big six-cylinder M20, it's not true that all four-pot engines are rubbish; after all, the M3 was powered by the four-cylinder S14 lump.
If you want more poke from your 318i without the drinking problems inherent of the bigger engines, then look no further than the M42 engine. This fizzy little four-banger features the same 1.8 litre displacement as the other E30 engines, but with double the valves (16 in all) to crank the power up to 140bhp. Combined with a simple drop-in swap procedure and easy-to-find spares from the E36, the M42 swap is a great way to liven up the smaller-engined E30 models.
Identification
M44 crank sensor location:
M42 crank sensor location:
Parts List
You need: 1. M42 engine 2. E30 M42 engine loom and ECU (will work with E36 engines also, saves having to adapt E36 looms and causing issues!) 3. Coil packs and HT leads or COP conversion 4. M42 exhaust manifold 5. 318iS exhaust system 6. M42 coolant hoses 7. M42 AFM to TB boot 8. Getrag 240 gearbox 9. 318iS prop
A note on the Getrag 240 gear box. There are two types: one was fitted to the M40 and the other to the M42. Note that the M42 ones have a different output flange. You need the one with the flange further away in order to use all standard 318iS parts.
Coil packs
Single mass:
Ancillaries
