Interior
Dashboard
Instruments
Main article: Instruments
Controls
- Wash/Wipe stalk
- Indicator stalk
- OBC stalk - if fitted
- Hazard Lights
- Heater Controls
- Rear Demister
- Heated Seats - if fitted
Vents
Heating
Main article: Heating
Aircon
Main article: Aircon
Upholstery
Main article: Upholstery
The upholstered items of your E30 were chosen by the original purchaser, based on recommendations by the dealer. The selection affected the colour of the seats and door cards. Learn more about upholstery options.
Seats
Main article: Seats
While the types of upholstery did change year on year, the physical shape did not, meaning seats are compatible for each model before and after the facelift.
Each E30 is equipped with two front seats and a rear bench. All front seats are interchangeable, although 4-door and Touring seats do not feature the tilt mechanism of 2-door and Cabriolet seats. However, the rear bench is specific to each model.
Learn more about Seats.
Door Cards
Door cards were available in cloth, vinyl or leather. Door cars are as specific to the vehicle as the doors themselves; therefore they share the same compatibility.
Unfortunately, it is not possible to disassemble a door card. For that reason, repairing any damage to the upholstered section of a doorcard requires a full retrim of the card.
Carpet
All E30 carpets are a two-piece component. The main part extends from the bulkhead to the rear passenger footwells, and is identical across all models. Don't be conned by shady traders; there's no such thing as a "sport" carpet. The rear section sits vertically and tucks under the rear seat, and varies between model types. This accommodates the different seat cushion shapes across the model range.
Two materials were used for E30 carpets. M20-engine models, Cabriolets and Tourings have a velour-type material, which can be dyed if needed. The lower 4-cylinder models have a nylon hard-wearing carpet which cannot be dyed.
Headlining
Loose Seat Back
Backrest Not Locking
