Seats
Revision as of 14:01, 6 September 2012 by Grrrmachine (talk | contribs)
Each E30 was fitted with the same seating arrangement. Two front seats bolt directly to the floorpan of the E30, and slide back and forth on rails for adjustment, while a solid rear bench provides space for three at the back. On Touring models, this rear bench folds down to allow boot access, with the seat bases tilted forward to increase the load area. Rear headrests were an optional extra.
All seats feature solid-mounted seat belts which mount to the seat base and the A- and B-pillars respectively.
Seats came in a variety of styles and upholstery options. While the standard seats are known as Comfort seats, the bulkier versions are known as Sports seats to keep your bum where it should be during aggressive cornering.
Front Seats
The physical style of the seat determined bolster height and thigh support; sportier seats are known as sports seats for a good reason.
Also available are Heated Seats, which provide a gentle warming sensation for your posterior when needed. These are controlled by switches mounted to the tunnel.
Rear Bench
Headrests
All front seats feature headrests from the factory, and these can be removed from the seat by pulling upwards sharply.
Seat Types
Aside from the model-specific differences, it was also possible to order specific types of seats for improved comfort and performance. The changes are made to the front seats, and make some seats worth more than others. Wooden bead mats were an optional aftermarket extra.
Comfort Seats
These are the standard E30 seats. They feature a mildly contoured shape with modest side bolsters on the base and upright part. The seat is able to slide and tilt, and fold over for 2-door versions.
Sports Seats
Fitted to all sport models, these seats feature more bolstering on the side than standard comfort seats, as well as extended thigh support on the base. These seats are also more adjustable, with the ability to raise and lower the height of the seat.
Having said that, with very little modification the following seats will physically fit into an E30:
  • E21 Recaro
  • E24 High-back Recaro front and rear
  • E36 M3/Coupe "Vader"
  • E46
Damaged Front Seats
Decades of wear and tear will take their toll on your front seats eventually. When that happens you'll need to strip your seats down and rebuild them with fresh foam and fabric. To take the edge off this daunting task, learn more about repairing seats.
