Steering
Rack
Tie Rods
PAS Pump
Steering Column
Steering Wheel
Main article: Steering Wheels
Maintenance
Faster Rack
While the steering of an E30 is a charm of feedback-response, neither too heavy or too light, many of the more spirited drivers find the standard rack too long, in the sense that it takes too many turns from one full lock to the other. Fitting a faster rack from a BMW Z3 is a common and simple upgrade, but for those looking for bigger increases, fitting a rack from an E36 M3 can bring dramatic improvements.
