ECU Pinouts
Revision as of 18:31, 17 February 2012 by Grrrmachine (talk | contribs)
Motronic 1.3 ECU plug
Jetronic
Jetronic's primitive management system only controlled fuelling, so the ECU is little more than an injection control unit. The control model uses a 25-pin plug, with Pin 1 at the cable end. Note that the ECU connector is accompanied by the C104, a small 3-pin plug that provides data for the Instruments.
Pin Colour Function Pin Colour Function Image
2 BR/BU Closed Throttle input 15
3 BR/BK WOT input 16
4 BK/YL Cranking signal 17
5 BR Ground 18 BU/BR Cancels deceleration fuel shutoff when A/C clutch is on
6 GN/RD Engine Load Output to Vacuum Control 19
7 GY/YL AFM input 20 GN O2 Sensor input
8 GN/VI AFM reference output 21
9 RD/WT Power input 22 WT/GN Fuel rate to Diagnostic plug
10 BR/RD Coolant Temp input 23
11 WT Barometric Pressure input 24
12 BR/YL Injectors and Econometer 25
13 BR Ground
C104
1 BL/BU Tachometer 2
3 WT Econometer
Motronic 1.0
Pin Function Pin Function Image
2 Idle switch 20 Main relay
3 WOT switch 21 Tachometer
4 Cranking signal 22 AFM Temp sensor
5 Ground/Crank PosS Gnd 23 Inlet Air Temp/Crank SpS Gnd
6 AFM ground 24 O2 sensor signal *
7 AFM signal 25 Crank position sensor 1
8 Crank speed sensor 1 26 Crank position sensor 2
9 AFM supply 27 Crank speed sensor 2
10 Auto only special 28 Water Pressure switch
11 Fuel consumption gauge 29 A/C switch (if installed)
12 30 +Inlet Air Temp
13 Water Temp 31
14 Injector output cyl 3&4 32
15 Injector output cyl 1&2 33 ICV pulse
16 Ground 34 ICV pulse
17 Ground 35 Injector ground
18
Motronic 1.1
Motronic 1.1 uses a much chunkier plug, fitting 55 pins into three rows. Unlike Jetronic and Motronic 1.0, pin 1 is now at the end furthest from the cable.
Pin Function Pin Function Pin Function Image
2 Ground 21 39 Programming voltage - Diagnostic Plug
3 Fuel pump relay control 22 Idle speed control 40 A/C on input
4 Idle speed control 23 O2 sensor heater 41
5 Evaporative purge valve 24 Ground 42 Park/ neutral input (auto only)
6 Engine Speed output- to instrument cluster 25 43
7 AFM input - pin 2 26 AFM common- ground pin 4 44 AFM air inlet temp- pin 1
8 Cylinder ID sensor input 27 Start input- to ignition switch and coil 45 Coolant Temp input
9 28 O2 input 46
10 O2 sensor ground 29 47 Engine speed input
11 30 48 Engine speed input
12 AFM reference output- pin 3 31 Cylinder ID sensor input 49
13 RXO - diagnostic plug 32 Econometer 50
14 Ground 33 51
15 Check engine light - to cluster 34 52 Closed throttle input - pin 1
16 Injectors 1,3,5 35 53 WOT input - pin 3
Note: TPS pin 2 is ground
17 Injectors 2,4,6 36 Main relay 54
18 Power input main relay 37 Power input - to main relay 55 TXD - diagnostic plug
19 Ground
Motronic 1.3
Motronic 1.3 uses the same engine loom as Motronic 1.1, and therefore the 55-pin plug remains the same. However, the small differences that crept into production during the lifetime of Motronic 1.3 mean that a few extra wires are in place, to control features such as ABS.
Pin Colour Function Pin Colour Function Pin Colour Function Image
1 BK Timing Control - to coil and O2 sensor 20 38 ABS and OBC cutoff for Injectors Motronic1 3Pins.jpg
2 BR Ground 21 39 GN/BU Programming voltage - Diagnostic Plug
3 BR/GN Fuel pump relay control 22 WT/GN Idle speed Close control 40 BK/GY A/C low pressure cutoff
4 WT/YL Idle speed control 23 BR/GR O2 sensor heater 41 VI/GY A/C On input
5 BR Evaporative purge valve 24 BR Ground 42 RD/BU Park/ neutral input (auto only)
6 BK Tachometer 25 43
7 GY/YL AFM input - pin 2 26 GY/BU AFM common- ground pin 4 44 GY/VI AFM air inlet temp- pin 1
8 BL Cylinder ID sensor input 27 GN Start input- to ignition switch and coil from OBC 45 BR/RD Coolant Temp input
9 28 BK O2 input 46
10 YL O2 sensor ground 29 BK/WT Vehicle Speed input from instrument cluster 47 BL Engine speed input
11 30 48 YL Engine speed input
12 GY/WT AFM reference output- pin 3 31 YL Cylinder ID sensor input 49
13 WT/YL RXO - diagnostic plug 32 WT/BL Econometer 50 ABS Deceleration Fuel Cut-Off Overide
14 BR Injector Ground 33 51 Auto Kick-Down Switch input
15 GY Check engine light - to cluster 34 52 BR/BL Closed throttle input - pin 1
16 BR/WT Injectors 1,3,5 35 53 BR/BL WOT input - pin 3
17 BR/YL Injectors 2,4,6 36 BR Main relay output 54 Automatic Transmission Torque Converter Lock-up Switch
18 RD Constant 12V from Battery 37 RD/BU Switched power from main relay 55 WT/VI TXD - diagnostic plug
19 BR/OR Main Ground
