ECU Pinouts
Jetronic
Jetronic's primitive management system only controlled fuelling, so the ECU is little more than an injection control unit. The control model uses a 25-pin plug, with Pin 1 at the cable end.
| Pin | Colour | Function | Pin | Colour | Function | Image |
| 1 | GN | Engine Speed input (RPM) | 14 |
| 2 | BR/BU | Closed Throttle input | 15 | |||
| 3 | BR/BK | WOT input | 16 | |||
| 4 | BK/YL | Cranking signal | 17 | |||
| 5 | BR | Ground | 18 | BU/BR | Cancels deceleration fuel shutoff when A/C clutch is on | |
| 6 | GN/RD | Engine Load Output to Vacuum Control | 19 | |||
| 7 | GY/YL | AFM input | 20 | GN | O2 Sensor input | |
| 8 | GN/VI | AFM reference output | 21 | |||
| 9 | RD/WT | Power input | 22 | WT/GN | Fuel rate to Diagnostic plug | |
| 10 | BR/RD | Coolant Temp input | 23 | |||
| 11 | WT | Barometric Pressure input | 24 | |||
| 12 | BR/YL | Injectors and |Econometer | 25 | |||
| 13 | BR | Ground |
Motronic 1.0
| Pin | Function | Pin | Function | Image |
| 1 | Ignition coil output | 19 | Ground |
| 2 | Idle switch | 20 | Main relay | |
| 3 | WOT switch | 21 | Tachometer | |
| 4 | Cranking signal | 22 | AFM Temp sensor | |
| 5 | Ground/Crank PosS Gnd | 23 | Inlet Air Temp/Crank SpS Gnd | |
| 6 | AFM ground | 24 | O2 sensor signal * | |
| 7 | AFM signal | 25 | Crank position sensor 1 | |
| 8 | Crank speed sensor 1 | 26 | Crank position sensor 2 | |
| 9 | AFM supply | 27 | Crank speed sensor 2 | |
| 10 | Auto only special | 28 | Water Pressure switch | |
| 11 | Fuel consumption gauge | 29 | A/C switch (if installed) | |
| 12 | 30 | +Inlet Air Temp | ||
| 13 | Water Temp | 31 | ||
| 14 | Injector output cyl 3&4 | 32 | ||
| 15 | Injector output cyl 1&2 | 33 | ICV pulse | |
| 16 | Ground | 34 | ICV pulse | |
| 17 | Ground | 35 | Injector ground | |
| 18 |
Motronic 1.1
Motronic 1.1 uses a much chunkier plug, fitting 55 pins into three rows. Unlike Jetronic and Motronic 1.0, pin 1 is now at the end furthest from the cable.
| Pin | Function | Pin | Function | Pin | Function | Image |
| 1 | Timing Control - to coil and O2 sensor | 20 | 38 |
| 2 | Ground | 21 | 39 | Programming voltage - Diagnostic Plug | ||
| 3 | Fuel pump relay control | 22 | Idle speed control | 40 | A/C on input | |
| 4 | Idle speed control | 23 | O2 sensor heater | 41 | ||
| 5 | Evaporative purge valve | 24 | Ground | 42 | Park/ neutral input (auto only) | |
| 6 | Engine Speed output- to instrument cluster | 25 | 43 | |||
| 7 | AFM input - pin 2 | 26 | AFM common- ground pin 4 | 44 | AFM air inlet temp- pin 1 | |
| 8 | Cylinder ID sensor input | 27 | Start input- to ignition switch and coil | 45 | Coolant Temp input | |
| 9 | 28 | O2 input | 46 | |||
| 10 | O2 sensor ground | 29 | 47 | Engine speed input | ||
| 11 | 30 | 48 | Engine speed input | |||
| 12 | AFM reference output- pin 3 | 31 | Cylinder ID sensor input | 49 | ||
| 13 | RXO - diagnostic plug | 32 | Fuel rate output- to instrument cluster | 50 | ||
| 14 | Ground | 33 | 51 | |||
| 15 | Check engine light - to cluster | 34 | 52 | Closed throttle input - pin 1 | ||
| 16 | Injectors 1,3,5 | 35 | 53 | WOT input - pin 3
Note: TPS pin 2 is ground | ||
| 17 | Injectors 2,4,6 | 36 | Main relay | 54 | ||
| 18 | Power input main relay | 37 | Power input - to main relay | 55 | TXD - diagnostic plug | |
| 19 | Ground |
Motronic 1.3
Motronic 1.3 uses the same engine loom as Motronic 1.1, and therefore the 55-pin plug remains the same. However, the small differences that crept into production during the lifetime of Motronic 1.3 mean that a few extra wires are in place, to control features such as ABS.
| Pin | Colour | Function | Pin | Colour | Function | Pin | Colour | Function | Image |
| 1 | BK | Timing Control - to coil and O2 sensor | 20 | 38 | ABS and OBC cutoff for Injectors |
| 2 | BR | Ground | 21 | 39 | GN/BU | Programming voltage - Diagnostic Plug | |||
| 3 | BR/GN | Fuel pump relay control | 22 | WT/GN | Idle speed Close control | 40 | BK/GY | A/C low pressure cutoff | |
| 4 | WT/YL | Idle speed control | 23 | BR/GR | O2 sensor heater | 41 | VI/GY | A/C On input | |
| 5 | BR | Evaporative purge valve | 24 | BR | Ground | 42 | RD/BU | Park/ neutral input (auto only) | |
| 6 | BK | Engine Speed output- to instrument cluster | 25 | 43 | |||||
| 7 | GY/YL | AFM input - pin 2 | 26 | GY/BU | AFM common- ground pin 4 | 44 | GY/VI | AFM air inlet temp- pin 1 | |
| 8 | BL | Cylinder ID sensor input | 27 | GN | Start input- to ignition switch and coil from OBC | 45 | BR/RD | Coolant Temp input | |
| 9 | 28 | BK | O2 input | 46 | |||||
| 10 | YL | O2 sensor ground | 29 | BK/WT | Vehicle Speed input from instrument cluster | 47 | BL | Engine speed input | |
| 11 | 30 | 48 | YL | Engine speed input | |||||
| 12 | GY/WT | AFM reference output- pin 3 | 31 | YL | Cylinder ID sensor input | 49 | |||
| 13 | WT/YL | RXO - diagnostic plug | 32 | WT/BL | Fuel rate output- to instrument cluster | 50 | ABS Deceleration Fuel Cut-Off Overide | ||
| 14 | BR | Injector Ground | 33 | 51 | Auto Kick-Down Switch input | ||||
| 15 | GY | Check engine light - to cluster | 34 | 52 | BR/BL | Closed throttle input - pin 1 | |||
| 16 | BR/WT | Injectors 1,3,5 | 35 | 53 | BR/BL | WOT input - pin 3
Note: TPS pin 2 is ground | |||
| 17 | BR/YL | Injectors 2,4,6 | 36 | BR | Main relay output | 54 | Automatic Transmission Torque Converter Lock-up Switch | ||
| 18 | RD | Constant 12V from Battery | 37 | RD/BU | Switched power from main relay | 55 | WT/VI | TXD - diagnostic plug | |
| 19 | BR/OR | Main Ground |
