ECU Pinouts
Jetronic
Jetronic's primitive management system only controlled fuelling, so the ECU is little more than an injection control unit. The control model uses a 25-pin plug, with Pin 1 at the cable end.
| Pin | Function | Pin | Function | Image |
| 1 | 14 |
Motronic 1.0
| 1 | Ignition coil output | 19 | Ground |
| 2 | Idle switch | 20 | Main relay | |
| 3 | WOT switch | 21 | Tachometer | |
| 4 | Cranking signal | 22 | AFM Temp sensor | |
| 5 | Ground/Crank PosS Gnd | 23 | Inlet Air Temp/Crank SpS Gnd | |
| 6 | AFM ground | 24 | O2 sensor signal * | |
| 7 | AFM signal | 25 | Crank position sensor 1 | |
| 8 | Crank speed sensor 1 | 26 | Crank position sensor 2 | |
| 9 | AFM supply | 27 | Crank speed sensor 2 | |
| 10 | Auto only special | 28 | Water Pressure switch | |
| 11 | Fuel consumption gauge | 29 | A/C switch (if installed) | |
| 12 | 30 | +Inlet Air Temp | ||
| 13 | Water Temp | 31 | ||
| 14 | Injector output cyl 3&4 | 32 | ||
| 15 | Injector output cyl 1&2 | 33 | ICV pulse | |
| 16 | Ground | 34 | ICV pulse | |
| 17 | Ground | 35 | Injector ground | |
| 18 |
Motronic 1.1
Motronic 1.1 uses a much chunkier plug, fitting 55 pins into three rows. Unlike Jetronic and Motronic 1.0, pin 1 is now at the end furthest from the cable.
| Pin | Function | Pin | Function | Pin | Function | Image |
| 1 | Timing Control - to coil and O2 sensor | 20 | 38 |
| 2 | Ground | 21 | 39 | Programming voltage - Diagnostic Plug | ||
| 3 | Fuel pump relay control | 22 | Idle speed control | 40 | A/C on input | |
| 4 | Idle speed control | 23 | O2 sensor heater | 41 | ||
| 5 | Evaporative purge valve | 24 | Ground | 42 | Park/ neutral input (auto only) | |
| 6 | Engine Speed output- to instrument cluster | 25 | 43 | |||
| 7 | AFM input - pin 2 | 26 | AFM common- ground pin 4 | 44 | AFM air inlet temp- pin 1 | |
| 8 | Cylinder ID sensor input | 27 | Start input- to ignition switch and coil | 45 | Coolant Temp input | |
| 9 | 28 | O2 input | 46 | |||
| 10 | O2 sensor input | 29 | 47 | Engine speed input | ||
| 11 | 30 | 48 | Engine speed input | |||
| 12 | AFM reference output- pin 3 | 31 | Cylinder ID sensor input | 49 | ||
| 13 | RXO - diagnostic plug | 32 | Fuel rate output- to instrument cluster | 50 | ||
| 14 | Ground | 33 | 51 | |||
| 15 | Check engine light - to cluster | 34 | 52 | Closed throttle input - pin 1 | ||
| 16 | Injectors 1,3,5 | 35 | 53 | WOT input - pin 3
Note: TPS pin 2 is ground | ||
| 17 | Injectors 2,4,6 | 36 | Main relay | 54 | ||
| 18 | Power input main relay | 37 | Power input - to main relay | 55 | TXD - diagnostic plug | |
| 19 | Ground |
