ECU Pinouts
Jetronic
| Pin | Function | Pin | Function | Image |
| 1 | 14 |
Motronic 1.0
| 1 | Ignition coil output | 19 | Ground |
| 2 | Idle switch | 20 | Main relay | |
| 3 | WOT switch | 21 | Tachometer | |
| 4 | Cranking signal | 22 | AFM Temp sensor | |
| 5 | Ground/Crank PosS Gnd | 23 | Inlet Air Temp/Crank SpS Gnd | |
| 6 | AFM ground | 24 | O2 sensor signal * | |
| 7 | AFM signal | 25 | Crank position sensor 1 | |
| 8 | Crank speed sensor 1 | 26 | Crank position sensor 2 | |
| 9 | AFM supply | 27 | Crank speed sensor 2 | |
| 10 | Auto only special | 28 | Water Pressure switch | |
| 11 | Fuel consumption gauge | 29 | A/C switch (if installed) | |
| 12 | 30 | +Inlet Air Temp | ||
| 13 | Water Temp | 31 | ||
| 14 | Injector output cyl 3&4 | 32 | ||
| 15 | Injector output cyl 1&2 | 33 | ICV pulse | |
| 16 | Ground | 34 | ICV pulse | |
| 17 | Ground | 35 | Injector ground | |
| 18 |
Motronic 1.1
| Pin | Function | Pin | Function | Pin | Function | Image |
| 1 | 20 | 38 |
| 2 |
1- timing control - to coil and O2 sensor
20- unused
39- Programing voltage- diagnostic conector
2- Ground
21- unused
40- A/C on input
3- Fuel pump relay control
22- idle speed control
41-unused
4- Idle speed control
23- O2 sensor heater
42- Park/ neutral input (auto only)
5- Evaporative purge valve
24-Ground
6- engine speed output- to instrument cluster
25- unused
43- unused
7-AFM input - pin 2
26- AFM common- ground pin 4
44- AFM air inlet temp- pin 1
8- cyl. ID sensor input
27- Start input- to ignition switch and coil
45- coolant temp input
9- unused
28- O2 input
46- unused
10- O2 sensor input
29- unused
47- Engine speed input
11- unused
30- unused
48-Engine speed input
12- AFM- reference output- pin 3
31- Cyl. ID sensor input
49-unused
13- RXO- diagnostic connector
32- Fuel rate output- to instrument cluster
50- unused
14- Ground
33- unused
51- unused
15- Check engine light - to cluster
34- unsued
52- Closed throttle input - pin 1
16- injectors- 1,3,5
35- unused
53- WOT input - pin 3 Note- TPS pin 2 is ground
17- injectors- 2,4,6
36- Main relay
54- unused
18- Power input main relay
37- Power input - to main relay 55- TXD- diagnostic Connector
19- Ground
38- unused
