ECU Pinouts
Revision as of 09:30, 17 February 2012 by Grrrmachine (talk | contribs) (New page: The ECU is the very heart of your engine management system. Almost everything under the bonnet, and a lot of the stuff inside the car, connects to it in some way....)
Jetronic
Pin Function Pin Function Image
Motronic 1.0
2 Idle switch 20 Main relay
3 WOT switch 21 Tachometer
4 Cranking signal 22 AFM Temp sensor
5 Ground/Crank PosS Gnd 23 Inlet Air Temp/Crank SpS Gnd
6 AFM ground 24 O2 sensor signal *
7 AFM signal 25 Crank position sensor 1
8 Crank speed sensor 1 26 Crank position sensor 2
9 AFM supply 27 Crank speed sensor 2
10 Auto only special 28 Water Pressure switch
11 Fuel consumption gauge 29 A/C switch (if installed)
12 30 +Inlet Air Temp
13 Water Temp 31
14 Injector output cyl 3&4 32
15 Injector output cyl 1&2 33 ICV pulse
16 Ground 34 ICV pulse
17 Ground 35 Injector ground
18
Motronic 1.1/1.3
Pin Function Pin Function Pin Function Image
2
